h23 vtec oil jet clearance problem...
Old Aug 22, 2002 | 04:29 PM
bb1turbovtec's Avatar
Default h23 vtec oil jet clearance problem...
ok guys, i am using my h22a1 w/ h23 crank, rods, and type s pistons. here is my problem. I took it to a machine shop to assemble the bottom end. but, the crank webs just barely rub the base of the oil jet assembly. the machine shop says its fine and they cannot modify the jets any more than they have allready done. i dont know about this. what have other people done about this problem? thanks a lot!
Old Aug 23, 2002 | 07:51 AM
Default Re: h23 vtec oil jet clearance problem... (bb1turbovtec)
ok guys, is it really safe to run no jets? even under high temps? also, if i leave the jets in (it's slightly rubbing the base of the oil jet assembly) is this going to cause problems? thanks.
Old Aug 23, 2002 | 09:50 AM
boomslang's Avatar
If the crank hits the squirters when it rotates then take them out.
jprelude92
Jan 10, 2008 12:53 PM
crdcz03
Nov 26, 2004 06:09 PM
philafelman
Aug 9, 2003 01:26 PM
