DA Seatbelts not working
Old Jul 13, 2009 | 07:04 AM
Circaskaterr's Avatar
Default DA Seatbelts not working
In the car i bought not to long ago i noticed that the seatbelts dont work, the ones that go over your shoulder automaticly. I would like to find out why cause for 1 i feel weird having just the waist belt on and 2 im sure a cop wouldnt like it. I checked every single fuse in the fuse box and none of them are blown the cars wiring was kinda rigged when i got it so they might not even be plugged in so if someone could show me how i could check that it would be greatly appreciated
Old Jul 13, 2009 | 08:07 AM
RayYay's Avatar
Default Re: DA Seatbelts not working
I have this exact same problem on my 92 Integ that I just bought but only on my passenger side. So any help will be greatly appreciated
Old Jul 13, 2009 | 10:20 AM
Mindgamez's Avatar
I had the same problem. Apparently all Acura's have a lifetime warranty with safety things. I took mine to the dealer and they fixed it for free.
Old Jul 13, 2009 | 11:20 AM
pitchblacksvt's Avatar
Yeah just take it to the stealership they will fix it.
Old Jul 13, 2009 | 12:41 PM
TunerN00b's Avatar
Not just Acura, its a relatively new safety law. Safety equipment has an extended warranty.
I had the dealer replace the rails, sliders, motors, and belts on my 91 LS 2 years ago, no charge at all.
Old Jul 13, 2009 | 12:42 PM
EvenStar's Avatar
You should get that fixed. It's not safe to drive with broken seatlbelts.
Old Jul 13, 2009 | 02:00 PM
acuralovar's Avatar
do u still have the stock seats in there? underneath the seat theres a clip..see if its unpluged if its not then the motor took a crap
Old Jul 13, 2009 | 03:18 PM
boarderwayne's Avatar
http://www.g2ic.com/forums/showthread.php?t=23782
Old Jul 13, 2009 | 05:55 PM
RayYay's Avatar
This is awesome, I'm going to the dealership tomorrow. Wait a minute, this better not be some cruel joke....
Old Jul 13, 2009 | 10:07 PM
seanbev24's Avatar
not a joke, lifetime warranty on the seatbelts
Old Jul 14, 2009 | 06:33 AM
do you have to like call and make an appointment first or can you just go in?
Old Jul 14, 2009 | 12:39 PM
seanbev24's Avatar
I'd just call and make an appointment, cuz chances are they'll just have you make an appointment anyway if you just take it in.
Old Jul 14, 2009 | 12:45 PM
RayYay's Avatar
I just called my local Acura dealership and they confirmed that the electronic shoulder strap is NOT covered. However, my driver side shoulder strap does not lock when yanked on, but Acura says this is covered. The seat belt tensioner is covered but not the electronics
Old Jul 14, 2009 | 12:59 PM
DOHCterJEREMYb's Avatar
the motor for ur seatbelt is bad
Old Jul 15, 2009 | 01:22 PM
i checked that just now its plugged in but i dont think theres power getting to them period cause the person i bought the car from bought it from some guy that rigged some dash into the car that wasnt in there before i think its from a DA GSR but a lot of the wires were just twisted together so i had to fix some of that but i dont think the power for the seatbelts is even wired up anymore so how would i check that or where are the motors and ill just hook power up to them cause neither of the seatbelts work both sides just stay put
Old Jul 15, 2009 | 01:30 PM
TunerN00b's Avatar
Call a different dealer. Santa Monica Acura replaced the electronics on my 91 LS under warranty. Belts, rails, and motors were all replaced for me.
The motor is part of the belt system, and needs to be functioning properly for the belt to work properly. Find a different dealer that will replace it, and report the dealer that declined it to Honda.
Old Jul 16, 2009 | 10:08 AM
i dont know if this has anything to do with the seatbelts working unless it was the sensor that tells them to turn on but there a blue wire with a black stripe and white dots on and it a solid black wire with black dots under my dash not hooked to anything its just bare wires
Old Jul 16, 2009 | 08:14 PM
gotgohan's Avatar
yo I went to my acura and they told me if its any physical sign of exterior damage to the vehicle that could effect the seat belts they will charge for 120 for looking at it lol but then I found out that my seat belt module was unplugged when dying me carpet so that saved me a trip
Old Jul 16, 2009 | 11:37 PM
da9leo's Avatar
I <3 DA's
i threatened to report them, and they changed there minds
replaced everything on the drivers side for free
nukefivesix
16
Feb 9, 2010 06:51 PM
drtyhatch
13
Dec 14, 2005 04:43 AM
A.S.I.M.O
Nov 20, 2004 07:21 AM
2K1 BLK ITR
Nov 6, 2001 12:33 PM
