any possible way to fit 6x9s in the rear of a 95 4 door civic
Old Jul 12, 2009 | 07:29 PM
euroborn1's Avatar
Default any possible way to fit 6x9s in the rear of a 95 4 door civic
i'm sure someone has accomplished that before
Old Jul 13, 2009 | 03:40 PM
Skip01's Avatar
Default Re: any possible way to fit 6x9s in the rear of a 95 4 door civic
Not without cutting...but i did it too my other 95 4dr, not hard
Old Jul 14, 2009 | 12:37 AM
8520's Avatar
Old Jul 14, 2009 | 05:45 AM
fcm's Avatar
fcm
Old Fart
Although not that hard to do, it's not worth doing as rear speakers should be for rear fill only, 6.5" speakers can easily supply rear fill, also not worth weakening the rear deck by cutting it up. 94
Old Jul 14, 2009 | 08:44 AM
ken9's Avatar
IF those 6 x 9 cannot fix at the rear then just make a box for it. If you believe that theives would take it then don't bother putting it at the back. Would bother cutting the rear deck because it make look bad.
Old Jul 14, 2009 | 10:18 AM
Skip01's Avatar
Indeed right here....idk if ill even put anything in the rear my new project Civic honestly.
Old Jul 14, 2009 | 11:26 AM
fcm's Avatar
fcm
Old Fart
A mono rear fill, [no highs] can help imaging, move sound-stage up and eliminate left/right bias on the front speakers. 94
Old Jul 14, 2009 | 02:32 PM
Skip01's Avatar
Yeh...thats all im concerned with...nothing crazy SQ but i do want a good image on the front dash.
You mean like a center stage in the rear or none?
Old Jul 14, 2009 | 07:30 PM
fcm's Avatar
fcm
Old Fart
Doh!!, I missed the OPs question, 6x9s in the front doors, [not the rear deck].
Absolutely not worth it, and never cut your doors if you do not have to.
Skip01
Technically you only need 2 speakers, there are only two channels in stereo, a left and a right.
Because a car is a poor "sound room" it can be very hard to get good staging and imaging, because the front speakers are almost always installed in the doors, low and to the left and right of you instead of in front of you an undesirable thing happens, "left/right bias", if you close your eyes while listening to the music you hear the music coming from the speakers, meaning if you "look", [eyes closed] towards where the sound is coming from and then opened your eyes you would be looking at a speaker, the left or right one instead of straight ahead, like "5th row center" at a concert hall.
Left/right bias can pretty much eliminated by adding rear fill, mid-range and lower only, no tweeters, [highs] high frequencies are very directional, [easy to hear where they are comming from] so highs behind you will tend to move the sound stage back, not a good thing, stereo, [left and right information] behind you will also move the sound stage back and make proper imaging very hard if not imposible the solution is to have a mono or mixed mono signal behind you, take any pair of rear speakers, [even stock ones], disable/remove tweeters, wire the speakers in series to increase impedance and wire them to a mono or bridged amp, cross them over as low-pass 5000Hz or lower, try it you will like it. 94
Cityblue
Honda Civic (2001 - 2005)
Jul 20, 2017 12:04 AM
street_ride14
Oct 1, 2014 05:16 PM
