92 Accord with Intermittant Power Door Lock
likely you have a bad actuator for that door. Unless you have an electrical problem. Have you had that door worked on or replaced lately? If not, it's probably the actuator.
Thank you very much Kchungb! Would you trust getting one of these from ebay, or a "Pick ur Parts" sort of place, or should I just "belly up to the bar", and go to Honda?
Thanks!!
Thanks!!
A new one from the honda website I usually go to (www.hondaautomotiveparts.com) is $165. You can try your luck at a used one. I'd estimate it would be about 40-50 bucks, so it's up to you as to what it's worth for you high mileage 92.
Hope that helps.
Hope that helps.
tlmg21700
Feb 19, 2007 10:25 AM
