FS: EG Hatch, B16/GSR swap, brakes, suspension, ignition, fuel, nitrous, tuned
Old Jul 12, 2009 | 12:30 PM
sweet's Avatar
Icon7 FS: EG Hatch, B16/GSR swap, brakes, suspension, ignition, fuel, nitrous, tuned
alright, due to recent changes in my work (currently not being employed) i thought i would put up my 92 EG Hatch for sale. i have had this car for about 7 years. i have spent countless hours and alot of money on swapping and upgrading parts over the past 5 years. i would like to keep it and fix the little things here and there, but due to not having any money i don't have much choice. this car is NOT my daily driver, and though the engine, transmission, ignition and fuel components have been in it a little over 4 years there are not many miles on them since everywhere i drive is very close to home. i will give an overview of what's in it below, but at this time there is way too much to detail. so i will update at a later time, or respond to questions through PM's about all the details. any questions or if you need pics please LMK, just PM me.
if you need a car that looks like a show car, then this one may not be for you
if you need a car with an interior other than front seats and a dash, then this may not be for you
***ALL PARTS WERE INSTALLED NEW WHEN THE ENGINE WAS REBUILT JUST OVER 4 YEARS AGO--INTERNALS, SEALS, GASKETS, BEARINGS, FASTENERS, CLUTCH, VALVETRAIN, EXHAUST SYSTEM (EXCEPT THE HEADER) SKUNK2 IM, SKUNK2 CAMS & GEARS***
BODY: infamous rust on rear quarter panels, faded paint on roof, needs a new front bumper, a mirror, a fender liner and possibly a hood
ELECTRICAL: SVR deep cycle battery, gold connectors, new ground wires, 2 new front speakers w/ crossovers, moderately used JVC head unit, small lightweight amp, lots of wires for all the components, push button start ignition also added
INTERIOR: only 2 black GSR seats, a gray dash (no glovebox), and gray center console with shifter cover--YES, IT'S STRIPPED INSIDE, LOL
BRAKES: 99 GSR full brake/arm swap, Hawk HPS pads, stock rotors
SUSPENSION & WHEELS: KYB GR2 shocks (almost new), Ground Control coilovers, GSR front and rear sway bars, front and rear braces, 14" black OEM wheels with Yokohama rubber
IGNITION: MSD Digital 6+ (brand new), MSD Blaster SS coil, MSD cap, NGK wires and plugs
FUEL: Walbro 255 HO pump, RC 440cc injectors, AEM FPR, gauge at filter
ENGINE: built B16A block (everything but sleeves, 11:1 C/R), P&P built GSR head with Skunk2 tuner 1 cams and gears, Skunk2 original style IM, knock-off Rage SS header, full 2.5" SS exhaust, stock GSR TB, basic intake with new filter, full size Integra radiator---ONLY RUN WITH ROYAL PURPLE OIL AFTER THE BREAK IN PERIOD
TUNING: P28 with Hondata S100, tuned by my friend Jeff at Evans Tuning, made 165WHP on the dyna-pak before the header upgrade (crap header and NO nitrous use!).
TRANSMISSION: GSR trans with ITR LSD, Action 2MD clutch, OEM flywheel
NITROUS: please note: the nitrous system hasn't been fully installed yet, NO nitrous has been run through this engine yet (nor any boost). this is a N/A only engine for the 4 years and several months i've had it installed!----NX NXL kit (used), almost new 15# bottle with new bottle line fitting, used NOS bottle heater, new NOS bottle mounted gauge and fitting, WOT switch mounted, new Fuel Pressure safetly switch. i also have a nearly new NX bottle opener which is up for sale already. only includes the 100 shot jets, so 25 to the wheels per cylinder. all i have to do to finish it is some wiring, put the bottle fitting and gauge on and get the bottle filled. i've spent $950 so far over the past 4 months on the nitrous system, not including the NX opener or new MSD Digital 6+ ignition. for now installation completion is on hold until i figure things out.
car runs great overall, but will need rear brakes very soon. also will need a valve adjustment and oil change soon. included for whoever buys the car will be the extra sets of new NGK plugs, 4 quarts of Royal Purple oil and the OEM oil filters i have.
PRICE IS $4,500 OR BEST REASONABLE OFFER, INCLUDING A COMPLETED NITROUS SYSTEM WHICH WILL BUMP IT UP TO ABOUT 275WHP (WHEN I FINISH THE INSTALLATION)
Old Jul 12, 2009 | 05:17 PM
sweet's Avatar
Default Re: FS: EG Hatch, B16/GSR swap, brakes, suspension, ignition, fuel, nitrous, tuned
Bump
Old Jul 13, 2009 | 06:31 AM
sweet's Avatar
Morning bump
Old Jul 13, 2009 | 01:11 PM
92egvx's Avatar
looks like alot of work...glws
Old Jul 14, 2009 | 08:50 AM
sweet's Avatar
thank you sir! yes, lots of work swapping everything out for upgrades. the body is not in the best shape (since i really don't have any real body work experience). but it runs great overall and there is alot of labor put in over the past 5 years.
Old Jul 15, 2009 | 12:05 PM
sweet's Avatar
Here's some more info:
B16A block--- low original miles when rebuilt, Eagle H beam rods, Arias pistons and rings (CTR sized, tops and side skirts "deburred"), ARP headstuds, New OEM pumps, HG, bearings, seals and gaskets. Stock bore and stroke. just over 11:1 C/R with the GSR head.
B18C1 head--- moderate miles when rebuilt, P&P, Portflow 32 valvespring set, Ferrea SS valves, Skunk2 stage 1 tuner cams, Skunk2 tuner IM (untouched), Skunk2 tuner cam gears, cut VC for cam gears, new OEM valve stem seals
***ALL PARTS INSTALLED NEW WHEN BLOCK AND HEAD WERE REBUILT***
Old Oct 19, 2009 | 12:15 AM
vw eater's Avatar
do you still have the nxl kit? any pic's? thanks
ILUVTEC
Jun 13, 2016 08:09 AM
JamesH74
Nov 12, 2015 08:11 PM
fungus mungus
39
Mar 9, 2011 04:04 AM
hondachris1994
Aug 28, 2010 01:30 PM
