CRANKSHAFT will NOT spin!?!?
Old Jul 12, 2009 | 11:21 AM
webster426's Avatar
Default CRANKSHAFT will NOT spin!?!?
I am doing my timing belt and got everything reinstalled. When I tried to manually turn over the engine a couple of times....nothing happened. I can not spin my crankshaft.
I took off the timing belt and STILL can not turn it. WTF do I do!?
Old Jul 12, 2009 | 11:55 AM
webster426's Avatar
Default Re: CRANKSHAFT will NOT spin!?!?
whoever tried to PM please try again......it did not go through....thanks!
Old Jul 12, 2009 | 01:01 PM
big_daddy234's Avatar
try going the other way... your pistons may be sitting on the valves, chances are you installed the belt wrong... try turning the cam or cams to open and close different valves and try again, make sure all valves on cyl #1 are closed and bring that pistion to the top of its travel and put the belt back on
also a good idea to refer to your manual if you have one.
Old Jul 12, 2009 | 01:13 PM
webster426's Avatar
i was told to only turn the pulley counter clockwise.....unless moving just a little bit in the opposite direction.
and if the cam is at TDC.....all pistons should be at equal height...
Old Jul 12, 2009 | 03:38 PM
bluedlude's Avatar
is your car in neutral?
Old Jul 12, 2009 | 04:19 PM
webster426's Avatar
Yeh I got everything running......engine runs great! Thanks anyway guys. Nothing was wrong to begin with......still not sure why it wouldnt turn over....but when i started the engine it was well timed and ran great!
Old Jul 12, 2009 | 04:35 PM
PyroProblem's Avatar
HIGH COMPRESSION FTW!
FYI- when the cams are timed, everything is setup to be at #1 TDC, which means the #1 piston is all the way up.
good job.
Atauto
Honda CR-V & Element
Apr 27, 2015 02:06 AM
VSBB6
Aug 13, 2005 01:17 AM
munscher
Apr 17, 2005 08:26 PM
NateTEG95
Jul 23, 2003 12:31 PM
dallasyoung
Feb 17, 2003 10:29 PM
