93 civic Si B16 ITR trans..... what axles?
simply put as the title says i have a 93 civic Si with a B16 and an ITR transmission. I need to know what axles i needs cause both of them started clickling like a day apart... its not constant. but enough to know that i need to replace them.
Any help would be appreciated
Any b-series axles will be compatible as long as they match the half shaft. I have a b16 with gsr trans and use 94-01 integra LS axles.
Here ill make it easy
http://cgi.ebay.com/ebaymotors/eg-92...6171810004r596
If you just wanna know what kind you should be able to use 99-00 civic si axles.
thanks gentleman.... I appreciate it ... I was almost sure i could use integra axles but just needed the reassurance... thanks again
streetcartuner
May 30, 2007 05:54 AM
