94 Accord Power issues...
Old Jul 12, 2009 | 08:06 AM
beerguy6903's Avatar
Default 94 Accord Power issues...
Okay, I have a 94 accord ex... F22b2 yada yada yada... I was driving around last night, just cruisin at about 40mphs, when suddenly my speedo decided to start jumping around. I noticed it a little bit, not too bad though. Then about 5 minutes later, it was going from 60 down to 0 then just started bouncing around everywhere.... I got on the highway to head home, started shifting and noticed a severe stutter in the acceleration. I'm dumbfounded with what it could be. I was thinkin coil or ignitor maybe, idk... Any help would be greatly appreciated as this is my only damn car... thanx ahead of time...
Old Jul 12, 2009 | 08:51 AM
bobinator5000's Avatar
Default Re: 94 Accord Power issues...
Sounds like speed sensor. Honda automatics shift based on speed sensor input so they know things like shift advance and acceleration. Check your TV cable (should be one going to the trans); or the honda equivelant as well as all of your vacuum hoses.
The stutter was probably caused by the torque converter failing to lockup. Check your trans fluid.
Old Jul 12, 2009 | 10:03 AM
with that, I forgot to mention that this is a 5 speed... so anything else man? I've been hearing maybe a VSS???
Old Jul 12, 2009 | 06:47 PM
Splitf22's Avatar
If the Speedo is jumping, chance the VSS...
TrevvTurnt23
Apr 24, 2015 02:54 PM
Patk
Aug 18, 2013 10:37 PM
ex voto
Aug 19, 2006 12:14 AM
Dmata
Apr 26, 2004 06:42 PM
