Will eg Brake booster fit my CRX?
Old Jul 12, 2009 | 08:06 AM
puertoricanboy90's Avatar
Default Will eg Brake booster fit my CRX?
When I was replacing my alternator yesterday, I happened to break one of the bolts to mount the M/C onto brake booster. So now, I have to replace that. My question is, could I use a bigger brake booster from a 94 EG ex on my CRX (88 Si)? If so, would it provide any benefit over the OEM booster (i.e. better braking power)? Would I have to use the EG M/C as well? Any help will be appreciated. Thanks
Old Jul 12, 2009 | 04:23 PM
88Hatchy's Avatar
Default Re: Will eg Brake booster fit my CRX?
Yes, the booster will bolt up to the firewall.
Yes, you will have to use the EG master cylinder.
Old Jul 12, 2009 | 04:58 PM
^^ Would this benefit my braking performance in any way? I would assume so because the eg M/C is considerably larger than mine. Any other modifications to get it to fit well?
Old Jul 12, 2009 | 05:15 PM
kojack_0's Avatar
not sure about eg master cylinder and brake booster, but i have an 01 gsr master cylinder and brake booster on my 88 crx si.
the mods i needed to do, to put it on, was that i had to bend one of the hard lines to the other side of the master cylinder and use a bigger 'connecting bolt'.
since the master cylinder is bigger, theres more fluid that goes through. meaning less travel on the brake pedal with a mean stopping power.
also did a rear disk conversion from a da gsr with the 40/40 prop valve when i swapped m/c.
lunalink's Avatar
can you use the M/C without swapping out the booster?
Old Jul 12, 2009 | 05:27 PM
kojack_0's Avatar
what m/c though?
Old Jul 12, 2009 | 05:30 PM
lunalink's Avatar
the eg? or DA or DC..lol.. which one will fit?
Old Jul 12, 2009 | 06:18 PM
kojack_0's Avatar
i think only the dc ones require both the master cylinder and brake booster together.
Old Jun 20, 2011 | 12:43 PM
cheeesboiger's Avatar
i'm currently asking a similar question on clubcivic. so i'm assuming this will work on my 91 civic si? the booster and MC are from 94 automatic civic hatch.
Old Jun 20, 2011 | 01:17 PM
CRX Toad's Avatar
I doubt EG will give you performance gain. It may but bigger doesn't always increase line pressure which translates to pedal feel.
You can you Integra 260v Booster and MC (non abs)
Integra 290v Booster and MC (ABS) may have to change rear MC fitting
Any Civic booster/MC but they must compliment each other. YOU ABSOLUTELY CANNOT USE ABS MC WITH NON ABS BOOSTER OR VISE VERSA.
Old Jun 20, 2011 | 01:27 PM
oh i'm not looking for more stopping power, i just want something that fits right now. the sale includes the MC as well. and from what i can seen in the pic he's also throwing in the brake pedal! anyway, i just need to know if i can use the eg brake booster and/or MC on my ef.
Old Jun 21, 2011 | 02:42 PM
bump
eggwhite22
Jul 30, 2009 07:06 AM
Panda hatch
Feb 2, 2007 07:41 PM
JKim0901
May 28, 2004 02:31 PM
