dropped cars
Old Jul 12, 2009 | 05:31 AM
wesk18's Avatar
Default dropped cars
what are the advantages n disadvantages??
i have my car drop about 1.25 with tokico blue sets i am wondering if this affected my handling, my car steering wheel moves from side to side while driving at slow and on fast speeds it feels that i dont have 100% control of my car sometimes it yerks to one side n it moves to the left side, my car was hit from the right side from previous owner n later after purchase i found out that i needed to replace right side knuckle, rear n front crossmember, rack n pinion n lower arms, i replace the axles too i did wheel balance, alignment only last thing i need is fram alignment. Do i need to adjust my tie rods from the rack n pinion?? i took my car to a frame shop they said i need my frame 1/2 inch pull back. This car doesnt drive straight on slow or fast speeds on a straight clean road free of cracks n everything that could make my car move on its own.
Old Jul 13, 2009 | 02:03 AM
silent1jt's Avatar
Default Re: dropped cars
lowering kit should IMPROVE your car handling on straight away and on corners, especially if you have stabilizer bars. the only disadvantage i can think off is that if ur car is too low and you live somewhere with bumpy roads youll be hitting the bumpers and might even crack them. i have a 94 ex with air bags so i can adjust my hight but i added the stabilzer bar on it and it really helps. you really need to get that frame re-aligned and possibly do another tire alignment.
Old Jul 13, 2009 | 09:00 AM
damn_import_culture's Avatar
your frame is the reason for pull you seriously dont think a 1/2" of bend in your frame is not going to cause pull youll have to get the frame straightened then get another alignment and that should solve these issues
Old Jul 13, 2009 | 09:33 AM
Bwill9886's Avatar
Yeah... that frame most likely plays at least a role in this.
Sounds like you replaced a lot of the handling components that could cause this, but there could be more.
The shocks and whatever lowering springs you have should not cause your problem, especially if they are new. As silent1jt said, your handling SHOULD be better.
Old Jul 13, 2009 | 09:42 AM
accord_raffi's Avatar
wow get that frame fixed before you kill yourself.
Old Jul 14, 2009 | 02:21 AM
wesk18's Avatar
yea man the car scares me sometimes!! ha
Old Jul 14, 2009 | 02:24 AM
wesk18's Avatar
alright thanks for the help everyone!!
i found another problem it should be easy fix? i guess, right side boot from the rack n pinion is damage!
Old Jul 14, 2009 | 02:26 AM
wesk18's Avatar
yea i've been wanting to buy some, what brand u have??
Old Jul 14, 2009 | 02:37 AM
silent1jt's Avatar
stabilizer bars i have MeganRacing on font and back wheels.
air bags: VIAR (just front and back switches)
Old Jul 14, 2009 | 06:57 AM
you should stop thinking about buying more suspension upgrades when your car needs to be made safe for the road first
Old Jul 14, 2009 | 11:11 AM
Bwill9886's Avatar
Priorities:
1. Fix frame
2. Fix boot
3. Check for any other bad parts
4. If all is well, then performance upgrades
Good luck!
Old Jul 14, 2009 | 11:17 AM
Originally Posted by Bwill9886
Priorities:
1. Fix frame
2. Fix boot
Good luck!
x2
Old Jul 14, 2009 | 11:21 AM
ravinaziankid's Avatar
First thing you should do is fix the frame before it gets worst.
Old Jul 14, 2009 | 11:40 AM
tougetuned_ef's Avatar
the sway bars just keep the car from leaning to the side in a corner. they wont do anything for you with your problem. unless you have the money to spend then go for it.
Old Jul 20, 2009 | 01:42 AM
wesk18's Avatar
i know etheir way no money for upgrading ha!!
but for the frame of course its a safety thing!!
Evoxrocks
Suspension & Brakes
Mar 9, 2016 10:29 PM
spectastic
Honda Civic (2001 - 2005)
10
Sep 6, 2013 02:01 PM
Atrain89
Suspension & Brakes
13
Sep 24, 2009 06:14 PM
Lan
Suspension & Brakes
Jul 5, 2005 08:22 AM
RudeLude
Apr 7, 2003 07:46 AM
