Timing advance with 93 octane?
Old Aug 22, 2002 | 02:17 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Timing advance with 93 octane?
I know 18 degrees is the highest within spec but since we run 93 here in Alabama is it possible that I could go to maybe 19 degree's without worrying?
Old Aug 22, 2002 | 02:28 PM
Black R's Avatar
25 Year Member
Default Re: Timing advance with 93 octane? (ActiveAero Ninja Edition)
.....i'm at 21 degrees with spec B's - although that's prolly NO help at all.
I wouldn't advance too far without being on the dyno. Too much advance is bad for power just like too much retard. There's a "sweet spot" somewhere and the only way to find it is on the dyno.
Old Aug 22, 2002 | 03:36 PM
JohnnyBoy's Avatar
Default Re: Timing advance with 93 octane? (Black R)
I've run 20 degrees on 93 no percievable problems.
Old Aug 22, 2002 | 03:39 PM
jond's Avatar
Good question. I wonder when acura decided on the safe range of timing, if they assumed the lowest high octane gas there is in NorthAmerica?
Old Sep 3, 2002 | 10:17 AM
badnan's Avatar
what do you guys think is safe octane for 18degrees timing?
89, 91, or 93?
right now im running 93, but just wanted to check
Old Sep 3, 2002 | 10:33 AM
uNF$@#!'s Avatar
Default Re: Timing advance with 93 octane? (badnan)
lol...
use 93 for 18+ degrees. if you can get more than 93 octane im sure you can advance the ignition timing some more.
blackeg
Engine Management and Tuning
Dec 19, 2013 04:28 AM
88h22_CRX
Feb 8, 2010 02:25 PM
ghostofnyc
Oct 11, 2005 04:07 AM
eh-D
Feb 6, 2002 05:25 PM
Got-VTEC
Nov 2, 2001 01:22 PM
