Should you be able to move clutch lever by hand?
I'm putting a ZC motor and Si transmission together and we got everything bolted up out of the car. But when we went to try out the clutch lever (where you put the clutch cable) it only moves a couple inches. Is this normal? Everything went together fine, no binding etc. But the lever only moves a couple inches. Will it work like it should once its in the car with the clutch cable hooked up?
maybe ur clutch cable is bad or u dont have it adjusted correctly...like maybe u have it adjusted to where the release fork is all the way up something just a couple guesses...correct me if im wrong but dont the cables get really stiff when theyre getting old??
When you adjust your clutch make sure you have like .5-1in of play in the pedal.
InJ3cted
May 24, 2005 02:16 PM
