Moisture Seeping into headlight
anyone have a tutorial on how to clean / reseal the head lamp? also what should i use to polish the front of the headlamp so i can make them look brand new?
these are OEM btw.
thanks for the help in advance
these are OEM btw.
put them in the oven, crack open, clean, put back in oven, reseal....there is a write up on clubrsx in the diy section....try searching next time
reseal them... then get a headlight refinishing kit (a good quality one)... 3M makes one you attach to a air tool and it buffs them out to look brand new. also once you reseal them go into your local Acura dealer and ask for headlight clamps for a TSX (it's part of a moisture bulletin on the TSX headlight) slap some extra clamps around the edges on your headlights so the seal stays extra tight.
plastix by meguiars is great polish for the outside of the headlights, just stick them in the oven on 140 for about 10 minutes and clamp them and it should seal any leaks.
