a little shock fork help?
Old Jul 11, 2009 | 09:06 AM
GroundZer0 336's Avatar
Default a little shock fork help?
ok heres the deal, im pretty sure i had da integra forks on my crx, then when i switched my susp. over to my civic and put my d2 coils on there i still had a big gap w/ them lowered all the way down. im pretty sure i used the forks from my crx and not the ones that were on the civic, and i know da ones are longer correct? except for taking them all off and comparing them does anyone know how to tell if they are from a da? i know theres dif. markings on them but i have no clue what they mean.
Old Jul 11, 2009 | 09:25 AM
Tyson's Avatar
Default Re: a little shock fork help?
EF and DA forks are the same. should say HL or HR on them. EG/DC are VL or VR.
Old Jul 11, 2009 | 10:24 AM
speckles's Avatar
^YUP! I think DC/EG forks are a tiny bit shorter, but at the same time the outer diameter of the strut is a lot bigger than the EF/DA struts, so you need DC/EG struts for the forks.
Old Jul 11, 2009 | 10:38 AM
Tyson's Avatar
Forks are the same length. Just bigger diameter.
Old Jul 11, 2009 | 01:15 PM
Crx Jimmy's Avatar
yes the da ones are the same height they are just fatter and let you slide the axle right through instead of having to take the forks off when changing axles
Old Jul 11, 2009 | 01:17 PM
Tyson's Avatar
NOT DA, but EG/DC.
read carefully.
Old Jul 11, 2009 | 01:45 PM
ok, so, i havnt had a chance to look but, are delsol and eg front susp. about the same, i know i had a dif. spindle before on the crx and had to use a delsol hub bearing, da or ef woudlnt work, i didnt try eg so i duno if they were the same. is the delsol fork longer? im just confused becuase i still have a really big gap with my d2s all the way down in the front but the back is about flush w the tire.
Old Jul 11, 2009 | 02:40 PM
Tyson's Avatar
del sol = EG
Old Jul 11, 2009 | 09:15 PM
thats what i thought...i hate my car. and man, tyson i know you know about everything about everything ef...i was pretty sure i did too but im getting pissed at my car... ive got ex front susp. w/ the bigger brakes and **** but that wouldnt make a dif.
BuiltnBought
Aug 17, 2015 01:46 PM
nukefivesix
13
Nov 11, 2009 06:53 PM
thevtecnician
Northern California (Sales)
May 5, 2009 02:35 AM
Integra_B18B
Dec 1, 2004 06:47 PM
