'94 GSR dash-Misc parts (DE)
I converted my car to RHD and have all the stock parts from my 94 GSR. Anything from the dash forward. Here is a list of things I can rattle off.
Stock cluster 128K on it. I can supply the wiring clips for the cluster also.
Dash (has screw holes above the center vents where someone mounted a tach at one point)
lower kick panels
climate control unit
power window switches with door harnesses and motors with rails
rear car wiring harness
engine bay wiring harness (missing headlight and turn clips)
stock GSR engine wiring harness
Dash wiring harness
Grey carpet (kinda dirty)
Stock front and rear OEM GSR seats 1994 style
SRS modules, sensors, airbags, wiring harness ect. Everything for the SRS!
ABS unit with all lines
Master cylinder for brakes
Master cylinder for the clutch with all lines to the trans (clutch master cylinder is about 4 months old)
stock pedals
steering column with light and wiper stalks and trim panels
wiper motor with arms (front and rear)
lower k frame with power steering rack lower control arms sway bar ect.
Any little parts you might need that you think I have, let me know. Best offer takes it.. I am located in Newark, DE
I can be reached at email at cozzie13@comcast.net
-Bob
lower kick panels
Dash wiring harness
stock pedals
-Bob
Hoock 90
Jul 20, 2010 12:57 PM
therotaryrocket
Jul 12, 2009 09:54 AM
