Rod bearing clearance issue
Old Jul 10, 2009 | 07:11 PM
USDM-EK4*'s Avatar
Default Rod bearing clearance issue
I started assembling my Ls block yesterday and ran into some rod bearing clearance issue. I am using Acl Duraglide bearings. Now #1 and 2 clyinder checked out fine at .001. But i am having trouble with the # 3 and 4 bearings. #4 has way too much clearance it was between .003-.002. Than #3 was way to tight it was over .001 to the point where i couldnt spin the crank because of it. Now my rods have been reconditioned because i'm using ARP rodbolts.
I was thinking of switching over to Oem bearings but didnt really have a clue on choosing the right color clearances? Can any give me some insights on it i really appreaciate it thanks.
Old Jul 10, 2009 | 07:43 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Rod bearing clearance issue
You should take the crank and rods to a machine shop and have the measure the crank journals and the ID of big end of the rod then report the results back here or PM me and I will help you to determine the proper bearing based on your desired clearance.
Old Jul 10, 2009 | 07:44 PM
all-mtr-teg's Avatar
Read hear
http://www.team-integra.net/sections...?ArticleID=409
Old Jul 10, 2009 | 08:00 PM
USDM-EK4*'s Avatar
I read my crank and it says B2 and my rods all have #3 stamped on it.
Old Jul 10, 2009 | 08:03 PM
USDM-EK4*'s Avatar
I followed the chart so that should be the green bearings? Do you think me running ARP rodbolts will throw my clearance off to run a different color bearing??
Old Jul 10, 2009 | 08:11 PM
mar778c's Avatar
Community Builder
I'll PM you a link because that site is blocked by the stupid HT filters.
http://www.***************.com/techn...7/aai.png.html
This place is getting more and more retarded.
Old Jul 10, 2009 | 08:17 PM
USDM-EK4*'s Avatar
Nah man its blocked in the pm to. E-mail it to at Daniel_lon_781@yahoo.com
Old Jul 10, 2009 | 08:27 PM
Did the crank ever get polished or machined? Were the rods reconditioned?
Old Jul 10, 2009 | 08:41 PM
racebum's Avatar
you can get around filters with spaces between letters or words.
Old Jul 10, 2009 | 09:30 PM
USDM-EK4*'s Avatar
yes my rods were reconditioned for the ARP rodbolts! The crank was nevered touched.
Old Jul 11, 2009 | 09:44 AM
b19coupe's Avatar
Post Re: Rod bearing clearance issue
I have assembled a few b-series blocks (50-100), and I have never had rod bearing clearances vary that much. There may be a problem with your crank and/or rods. When I run into clearances that are suspect, I take it to the experts at a machine shop and let them tell me what is wrong. They have all of these cool measuring gizmos and love to use them.
Old Jul 11, 2009 | 10:46 AM
USDM-EK4*'s Avatar
is it possible for me to switch bearings around? seeing how #3 clearance is too tight and #4 is on the loose end, maybe that make up the difference?
Old Jul 11, 2009 | 12:21 PM
USDM-EK4*'s Avatar
switch bearings around came out with the same results. Looks like me crank and rods are taking a trip to the machine shop!!
Old Jul 11, 2009 | 12:42 PM
dlaub25's Avatar
I'm really curious as to what site they are blocking??
Old Jul 11, 2009 | 05:22 PM
mar778c's Avatar
Community Builder
r e d p e p p e r r a c i n g. com
Old Jul 11, 2009 | 05:37 PM
racebum's Avatar
someone please tell me why this site is blocked?
the whole FSM online feature is pretty cool
Old Jul 11, 2009 | 06:05 PM
dlaub25's Avatar
Thanks, doesn't make sense to me though.
AssPenny
13
Feb 22, 2014 07:51 AM
eg4life1202
11
Jan 14, 2007 09:17 AM
hatchedzex
Oct 13, 2004 03:01 PM
v4lu3s
Jul 26, 2004 11:25 AM
hksbigboi4
Apr 16, 2004 07:48 AM
