d16z6 cylinder should I bu?
FEATURES:
-OEM USED 116,000 MILES D16Z6 CYLINDER HEAD
-OEM HONDA D16Z6 VALVETRAIN
-OEM CAM CAPS/ROCKER ARMS
-UNIT HAS BEEN POWERWASHED SO YOU GET A CLEAN PRODUCT
-HEAD HAS NOT BEEN MACHINED IN ANYWAY JUST A GREAT USED SOHC VTEC D16Z6 HEAD.
DOES NOT COME WITH VTEC SOLENOID,CAMSHAFTS OR VALVE COVER.
Is this a good deal for 149.98 shippded?
no. if it was complete it would be a good deal.
cams gonna run you $40+ shipped, vtec solenoid 20+ ( i have one) and dizzy will be 75+
i have a cam and a solenoid i will sell for $50 combined.
nope, especially if they power washed it. it would have to be used rightaway to prevent corrosion.
I would only get it if you need it. it does have decent mileage.
hm.. ok then. screw that one lol. What do you guys suggest? I found another also.
# HEAD
# INTAKE MANIFOLD
# FUEL RAIL WITH INJECTORS
# VALVE TRAIN WITH CAMS AND GEARS
# ROCKERS AND NUTS/BOLTS
# SPARK PLUG
# VALVE COVer
this one is 261 shipped. Would you go with that one? I'll end up changing the changing the valve cover on this one anyway because it doesnt have the vtec logo on it. but would you grab that one?
and sleeper do you have the wiring needed for the solenoid?
# HEAD
# INTAKE MANIFOLD
# SPARK PLUG
# VALVE COVer
no. it says it has a cam, and cam gear.
are you doing a mini me?
make sure the head has the back timing plate if you are. and you will need to get an adjustable cam gear. (timing will be off 1/2 tooth, if you dont)
yea I'm doin a mini me. by the by is your ecu for an AT? To be honest I'm not doin a mini me for power as much as that awesome vtec look and a little more get up not much but a little.
junk yard for the timing plate. you can get a cheapo cam gear on ebay for $15 then save up for a nice one, skunk 2 or something.
if you want the ecu $50, my paypal is didgie@embarqmail.com
will be shipped monday, and insured thru usps.
if you are going all out with the car, i have a chipped p06 (converted to p28) . $175 shipped. you don't need this ecu, unless you plan on doing some big things in the future lol. but its easy to chip a ecu yourself if you have sodering skills.
ok. just go to paypal . com and log it. go to SEND money. then you put my email address in. then 50 in the amount box. and hit send. (please put down "p28 ecu" in the send message or whatnot box) just so i know its from you. i sell a lot of parts lately lol.
ok sweet. I'm gonna grab the solenoid and ecu from you. I'll be paypalling said funds momentarily. I'll send you a note too saying something like trickster kid from H-T solenoid and ecu or something.
will I need anything else for my swap after all of this. I've got a water pump, timing belt and getting the dizzy cap and rotor.
get a new head gasket. and red rtv silicone. the silicone will be used to make a gasket for the vtec solenoid, and whatever else you need a gasket for. BESIDES THE HEAD GASKET LOL.
hahah lol. Ok thanks. just priced a head gasket for all of 13 bucks.
sweeet. red rtv can be bought at random auto parts stores I'm guessing?
yup. and might i make a suggestion, that you get a head gasket for a d16y8. 96-2000 civic 1.6L. its a metal gasket (will last forever lol) and you can remove the middle layer, and bump the compression up, for a few more ponies.
yah no prob. i was asking the same questions you are now like a month ago lol. now i've gone up to a full d15 auto. to d16z6 5 speed swap. im almost done. just waiting on a motor now.
