90 91 CRX and EF Civic hatch healight and turn signal are the same?
Howdy, basically, some big truck in front of me ran over some tire tread on the highway, with my face in the sun within a split second the tire tread shattered my headlight assembly and turn signal.
I have a friend whos gonna hook me up, but he has a 1990-91 EF Civic Hatchback that he wants to part out.
Are the headlights and turn signal assemblies the same? Bolt up and slide in the same? Same size, everything?
Any help is gladly appreciated, let me know whats up
Are you totally positive? They look pretty much alike but I'm assuming they don't bolt up the same, or maybe the size of them differ?
that same thing happened to me a big hunk of tire tread poped up and put a dent in my hood. but ya the corners are different.
yes i am positive. headlights and headlight brackets are identical. corner lights on the other hand are different. the crx corner lights have an angle at the end that goes up and towards the top of the door. whiles HB's have corner lights that angle downwards to bottom of the door. first light is crx second light is a hb both are 90-91 style
if you are referring to the bumper lights then the only ones that are interchangeable are the 88-89 civic with an 88-89 crx
Thanks a ton ya'll. Saved me the hassle. Gonna order new ones then. Can't seem to find used ones. Might check pick n pull.
Nov 10, 2012 07:12 AM
Stephen90Si
13
Aug 16, 2009 03:18 PM
EGKREW
14
Jun 25, 2008 03:57 PM
tur3oDC4
Apr 30, 2005 02:54 AM
