idles up and down
Old Jul 10, 2009 | 04:37 PM
shogee's Avatar
Default idles up and down
my buddy has an 92 accord that idles up and down between 1500-1000 rpm
help please.
Old Jul 10, 2009 | 06:00 PM
striker81's Avatar
Default Re: idles up and down
Checked all the connections, cleaned the throttle body, etc?
Old Jul 10, 2009 | 08:41 PM
shogee's Avatar
yes i took out iacv and cleaned it. with tb.
Old Jul 11, 2009 | 04:38 AM
GhostAccord's Avatar
If you have already cleaned the throttle body, IACV and FITV it could be a vacuum leak or an air bubble in the cooling system. Check for vacuum leaks and top up and bleed the coolant. Ensuring that you get all air out of the cooling system. After you have checked for vacuum leaks and bled the cooling system, reset the ECU.
Old Jul 11, 2009 | 07:57 AM
nus_dogg's Avatar
Both my H22 and F22 does it. I knew that the FITV would be the culprit. BAM, sucka ain't surging now. haha
Old Jul 11, 2009 | 08:01 AM
accord_raffi's Avatar
fitv
Old Jul 11, 2009 | 03:24 PM
shogee's Avatar
FITV? whats that. i not sure what that abbreviates. there is no vacuum leaks. haven't bled the system yet but will try, question though- how does an air bubble in the cooling system affect idle. the car didn't overheat,
Old Jul 11, 2009 | 04:08 PM
FITV = Fast Idle Thermo Valve. Look for it in the FAQ's sticky. This is all there dude. The fitv is operated by coolant temperature. There is a wax fitting that expands from the warmed up coolant which closes the fitv shut eventually. So an air pocket could potentially mess things up
Old Jul 13, 2009 | 07:40 AM
shogee's Avatar
thanks dude
torinharrington
Jun 14, 2013 07:29 PM
P. Hunter
Apr 7, 2013 05:46 AM
1992honda
Jun 17, 2011 08:07 PM
huge230
May 12, 2006 02:00 PM
dem0nk1d
14
Mar 22, 2006 05:57 PM
