JDM Integra Type R piston set
This set of Y.C.P. Type R pistons with the black teflon coating on the side and NPR ring set. Everything is new and in the box, the boxes are open to inspect the parts. The rings are still wrapped in its original plastic. The piston set come with wrist pins, one is out of the package to see if it would work with my eagle rods, sadly they did not. I could not use these pistons with my rods cause they are for the ls and the pistons are for a B18C1.
CYL.DIA: 81.00 MM
MODEL: B18C1
The advantage of having teflon coated pistons:
-Highlt resistant to heat
-increase strength
-Smoother running
-Improves piston life
-Reduced friction
-Essentlally eliminate scuffing and wear
-Improve cylinder sealing for less blowby and more power
-Help prevent damage from inadequate lubrication, especially during start-up
I need these sold so i can order the correct pistons, so pretty please help me out
The price for these are $250 with FREE SHIPPING in the U.S. OBO with you paying shipping.
CYL.DIA: 81.00 MM
MODEL: B18C1
-increase strength
-Smoother running
-Reduced friction
