turbo b18c wont start.. suggestions?
Old Jul 10, 2009 | 01:01 PM
turbodailydan's Avatar
Default turbo b18c wont start.. suggestions?
just built a turbo b18c, gone to start her up and it fires up but then cuts out, if you open the thottle it tries to rev but just cuts out..
any ideas?
cheers
Old Jul 10, 2009 | 01:11 PM
Top Speed's Avatar
Default Re: turbo b18c wont start.. suggestions?
any more specifics on the car. did you change injectors? whats done to the computer? What did u do to it, rebuild the engine or just put the turbo kit on?
Old Jul 10, 2009 | 01:15 PM
ive rebuilt the engine, and fitted turbo setup, still running stock itr injectors/cams etc, only difference is low comp pistons and forged rods and turbo setup..
Old Jul 10, 2009 | 03:05 PM
1DayIllBFast's Avatar
what type of engine management are you running? your not really feeding us info on your setup so we can help with your situation
Old Jul 10, 2009 | 03:17 PM
omiehomie's Avatar
x2 help us help you
Old Jul 10, 2009 | 03:39 PM
93turbo16's Avatar
If you are running stock cams, stock injectors, stock map sensor and stock ECU it should start up no problem.
I would double check your mechanical timing and make sure the cams line up with the crank.
Did you do a valve adjustment if the head was apart?
Old Jul 10, 2009 | 04:13 PM
waaBAAH's Avatar
see if your sensors for tps/map are swapped around. since you just installed the motor.
you throwing any codes? try cranking the car for awhile.. not more then 15 seconds..then release the key like you would normally. key II position. gauge lights should still be on.. dotn turn the key back to key I position.
check the codes if any.
get the idea of turbo out of your head for a second... think basics.
is the fuel pump priming?
pull the plugs and check what color they are... wet is fouled out
etc...
Old Jul 10, 2009 | 07:27 PM
VtecCarHauler's Avatar
Does it actually run then shut off or does it try to run but it keeps on missing? If it starts and runs for even 4 seconds then shuts of it is a tps/map problem or even IAC. Need more details. (ex: how long will it run for?, is it cranking but mis firing trying to start?)
Old Jul 11, 2009 | 12:08 AM
thanks for your input guys..
right, its stock managment at the moment, so only difference being is it has a turbo and lower cr pistons. SO it should start as normal.
when you turn the key, it starts straight away, but as soon as it starts, it dies, its not missfiring when it does run though, so im thinking something like a sensor too..
your help is much apreciated chaps thanks alot - dan
Old Jul 11, 2009 | 12:47 AM
right ive checked the TPS and MAP plugs and they are on the correct sensors.
ive pulled the plugs out and they are wet with fuel..
and i assume its sparking as it fires up on the key..
await your thoughts guys
Old Jul 11, 2009 | 01:12 AM
ive just checked the cam pulleys and the timing is spot on, so no probs there..
i also tried doing a fault code check but the engine light just stays on, and not throwing any codes up..
Old Jul 11, 2009 | 01:50 AM
also i dont know if its worth mentioning but when i removed the exhaust the wire snapped that goes to the sensor on the cat.. ( i assume this is just a heat sensor and doesnt effect the running of the car? )
Old Jul 11, 2009 | 03:43 AM
right just been out the garage again, i got it started and held it idleing at 3k rpm but as soon as you let off it dies, anyways im now getting fault code 14 which is the IACV
Old Jul 11, 2009 | 11:32 AM
thought id let you guys know ive been a complete GAY *** HOMO... turns out i mixed up the plugs on the idle control and knock sensor lol
school boy error
anyhow she runs now so just gotta fabricate this 3" exhaust system tommorow and get the ectune on there
thanks for the help
Old Jul 11, 2009 | 12:40 PM
Bailhatch's Avatar
haha we have all done stupid stuff like that.
Old Jul 11, 2009 | 09:36 PM
94gsrman's Avatar
what kind are of numbers you think you are putting down
crxb20vtec
Feb 9, 2011 02:22 PM
boostmywankle
Oct 24, 2008 05:11 PM
shibikku95
16
Aug 6, 2006 11:42 AM
crex23
Jun 5, 2006 01:10 PM
GSRfoedoe
Jun 1, 2005 07:07 AM
