2000 Si A/C compressor issue
Old Jul 10, 2009 | 12:43 PM
oldskoolaccord's Avatar
Default 2000 Si A/C compressor issue
My AC as of late has been clicking off and on constantly about every 1~2 seconds it keeps on trying to cycle,so the AC is cold/hot/cold/hot inside the car,it seems to do it more when the car is accelerating and I have seen it do it at idle as well, any ideas?
Old Jul 10, 2009 | 12:47 PM
ek-g6's Avatar
Default Re: 2000 Si A/C compressor issue
The AC pressure switch could be bad, if not a relay could be the culprit.
Old Jul 10, 2009 | 02:00 PM
IndySporty's Avatar
you are low on freon, the compressor is using up all of the freon in the low side and having to cut off because there is none left to compress. Add a can or take it to an A/C service shop and have them add some with dye, to find the leak.
Old Jul 10, 2009 | 02:05 PM
Former User's Avatar
Did you recently add refrigerant? If so, the A/C system may be overcharged.
Old Jul 10, 2009 | 02:19 PM
nope didn't add any freon and it isn't low already checked that-freon levels where fine.
Old Jul 10, 2009 | 02:25 PM
Do both the compressor clutch and condenser fan rapidly turn on and off, or just the clutch or fan? If both, then you might want to check the thermostat in the evaporator unit.
Old Jul 10, 2009 | 02:27 PM
just the compressor fan is on that I know of but I will double check it
Old Jul 10, 2009 | 02:37 PM
If the condenser fan runs continuously but the compressor rapidly cycles on and off, then check the pressure switch (already mentioned). If the switch is fine, then also check the compressor clutch clearance and the compressor thermal protector.
thinkskater007
114
Sep 3, 2012 06:36 PM
stockEJ
Aug 6, 2008 06:46 PM
stockEJ
Aug 6, 2008 06:45 PM
Mad Money
Aug 24, 2006 02:26 PM
old man honda
Apr 14, 2006 07:01 AM
