d15b setup questions
Old Jul 10, 2009 | 11:54 AM
SoFreshh's Avatar
Default d15b setup questions
so i have a jdm d15b vtec head on a d15z1 block. from what i've researched online this is the equivalent to a jdm d15b motor. also from what i've researched it's basically like having a d15 with z6 internals except the stroke length isn't as long. with all these specs in mind i typed these into a compression calculator switching p29 pistons for the factory ones and a 2 layer y8 headgasket. what shocked me is that the compression was rated at over 16:1 for the compression ratio. this didn't seem realistic to me considering the mini-me guides i've read have recommended p29 pistons to bump up compression but i've never heard of it being that high. what i was wondering is if i can actually use this setup in my car and what the actual compression ratio is.
Old Jul 10, 2009 | 01:30 PM
90Rexx's Avatar
Default Re: d15b setup questions
all i know is the CR isnt 16:1 .... your car wouldnt run like that... or if it managed to... it would run like crap
Old Jul 10, 2009 | 03:19 PM
SoFreshh's Avatar
well i checked on some other compression calculators and they turned out to be 13.3:1 is that ok to run without any problems?
Old Jul 10, 2009 | 04:27 PM
TheCivicMafia's Avatar
13.3 is insane amount of compression... Thats something thats hard to get even if you tried. Well atleast on a b18.
If it runs, i'd get it tuned, that doesnt seem right.
Old Jul 11, 2009 | 04:59 PM
SoFreshh's Avatar
Alrite well I figured in pg6 pistons from a d16a1 and the 2 layer y8 head gasket and that produced a 11.3:1 cr is that more suitable rather than a cr close to 13:1
Firstoost
Apr 26, 2006 05:30 PM
ZedEx
10
Jun 12, 2005 02:37 PM
DeadVet
Mar 30, 2005 04:37 PM
DeadVet
Feb 9, 2005 12:34 PM
90da4dr
Mar 9, 2003 05:18 AM
