Deer just took out both Pass side doors on '99 Civic EX sedan
Old Jul 10, 2009 | 08:06 AM
shortlid's Avatar
Icon3 Deer just took out both Pass side doors on '99 Civic EX sedan
My wife had a deer run into the side of her clover green Civic EX sedan. It hit the pass side door took off the mirrior bounced and then took out the pass rear door as well!! Anyone know how hard the doors are to replace? Anyone know a source for them.
Old Jul 10, 2009 | 08:49 AM
92eg_h22's Avatar
Default Re: Deer just took out both Pass side doors on '99 Civic EX sedan
junkyard...start searching for ones without dents...they do exist.
install is easy, helps to have a few friends around, then its as simple as sand/prime/paint
Old Jul 10, 2009 | 10:09 AM
Pothole987's Avatar
just 12mm bolts. you may have to remove the fender as well to make life easier for the front door. they are 10 mm bolts and require you to remove the sideskirt.
Old Jul 10, 2009 | 02:59 PM
98civdx's Avatar
Master Detailer
its pretty simple. and if you got a couple buddys it makes it alot easier to get them perfect.
Old Jul 11, 2009 | 06:25 AM
shortlid's Avatar
Icon2 Re: Deer just took out both Pass side doors on '99 Civic EX sedan
Can't I just use the bolts that hold the door to the hinge instead of taking the fender off for the front.
Old Jul 11, 2009 | 06:27 AM
shortlid's Avatar
I got doors for $100 of a '97 Civic LX sedan but the Blue green on them does not match! I was able to pop the worst dents out of the doors on the car. No broken paint, which is good might just use hammer and dolly to get it the best I can and just get a new mirrior.
Smithcraft
Paint and Body
Mar 14, 2018 02:16 PM
bam181
Aug 19, 2006 07:32 PM
xXx Justin xXx
Nov 28, 2004 12:14 PM
opiumdaze
Nov 3, 2004 06:34 PM
REVS-2-9K
Sep 2, 2004 02:16 PM
