Suspension question
Old Jul 10, 2009 | 07:50 AM
shahriar35's Avatar
Default Suspension question
Considering that my car has about 220k miles, I wanted to replace my bushings. I was curious about getting these control arm set. Because they are only $100 more than their adjustable ball joints. Also opinions on their craftmenship and design will be helpfull too.
94-97 TASPRO FRONT UPPER CONTROL ARM SET
TASPRO front upper control arms are the best and easiest way to improve handling and correct alignment on lowered Accords. These control arms are ready to bolt on with poly bushings and adjustable ball joints already installed. Just remove your original upper control arm and bolt these directly in their place. Poly bushings will give better handling and the adjustable ball joint will correct improper camber settings on lowered cars.
http://www.tasauto.com/Product/Browse.aspx?d=454&p=1
94-97 TASPRO ADJUSTABLE BALL JOINT
SALE!!!! $20.00 off regular retail price for a limited time.
TASPRO adjustable upper ball joints make front camber adjustments on your Accord quick and easy. Most camber kits move the complete control arm outward which causes your suspension to hit the inner wheel well on lowered cars. TASPROs adjustable ball joint will allow camber adjustment while keeping the control arm in its factory location. By replacing the factory ball joint, this sliding ball joint allows greater camber changes than standard control arm mount style adjusters. The ball joint is made to OEM specifications. Allows for +1.5 degrees to +3 degrees adjustment. Sold individually, two kits required per car.
Old Jul 10, 2009 | 06:30 PM
striker81's Avatar
Default Re: Suspension question
They look pretty solid.
snowblind7x
Apr 9, 2014 12:59 AM
matt1982
Mar 17, 2007 09:45 AM
killaj12
Feb 13, 2007 12:55 PM
integraL
May 19, 2006 08:16 AM
