4wd wagon partout. So many EF parts!!
Civic Wagon 4wd mudflap complete set. $90 shipped.
Complete civic wagon exhaust . Even includes the cat. $90 picked up.
Complete civic wagon exhaust 2.5” performance. Straight pipe removes cat. $90 picked up. Pics coming soon.
Civic wagon 4wd viscous coupler. $75 picked up.
Civic wagon rear differential. $125 picked up. $165 shipped.
Front knuckles fron 89 awd civic wagon. Includes upper control arms, knuckle, rotors, calipers, and pads. Lower ball joint boots are torn but the all ball joints are good. $90 picked up.
D-series OBD-0 power steering pump. $25 shipped.
D-series OBD-0 starter. $30 shipped.
D-series stock used clutch and flywheel. $50 shipped.
1989 AWD civic wagon stock suspension. $100 shipped.
Civic wagon drivers side mirror. $25 shipped.
EF headlight. $25 shipped.
EF gauge cluster with tach. $50 shipped.
4wd badge for steering wheel. Comes with 6 speed shift ****. $15 shipped.
14” white steelies from 1989 AWD wagon with good tires. Tire size is 175/70/14. These wheels clean up real nice with some steel wool. $125 picked up.
EF D-series axles. Came out of 89 CRX si. $40 picked up.
Last edited by red civic standard; Aug 6, 2009 at 06:43 PM. Reason: eliminate stuff that is already sold
Hi,
Interested in the wagon outer taillights set. Any cracks or damages? Also, do you know if those mudflaps will fit my 89 DX wagon? Also, looking for a pair of brown colored window crank handles that are in good condition if you got em.
Thanks
Thanks
actually I'm also interested in the Complete MPFI swap for my wagon...what the heck I could use more power.
throttle + clutch cable as well
pmed
pmed
Engine wiring harness is sold
A/C compressor is sold
Alternator is sold
Rear driveshaft is sold
MPFI swap is sold
Clutch cable/throttle cable/VSS cable sold
Main relay sold
Taillights are sold
Alternator is sold
MPFI swap is sold
Main relay sold
Taillights are sold
Interested on the driveshaft.. Do You still have it? i Will buy asap. I'm in area code 98058. Let me know rdevera06@yahoo.com thanks.
