What combo
Ok so im going racing tomm night with my buddy and his manager at work. I think that my clutch is going to go out and its going to be sooner THEN later. My buddy and i have done many tanny installs and motor installs. So labor is nothing for me. I just want to kno what clutch to get for my car. ALso going to change out the flywheel out to.
Should i get the ACT 11.4lbs 8.4lbs or the exedy 9lbs or the clutchmaster flywheel. What clutch should i get? I go to the track maybe once a year and race at teh drag stripe. I want the clutch to last me awhile so maybe a stage 1. I drive my car hard at times. Dont plan on doing to much more upgrading in power. What brand is good ect ect.
Thanks for all the help.
well with a lighter flywheel, you're going to have more of a rev hang on top of the rev hang we have from the factory. especially the 8.4 lb. but acceleration is going to the best with the lightest flywheel, but off the line traction is going to be a bigger issue with a lighter flywheel as well. as far as clutches, i would just get stage 1 act. anything higher, like rico said, is pointless with your setup. unless you plan to s/c or turbo.
yea i kno i want the stage 1 just what brand?? And i just did some reading on flywheels. I think i might wanna get the 11.4. Lighter then stock but not so drastic. I want to be able to drive the car DD and not have trouble. WHen you guys go to change otu your clutch and fw what will you get?
11.4 is a good choice, or u can go type-r with the 10lb. but i dont plan on changing my flywheel and clutch soon, but if i did, i would go act stage 1 with an 8lb flywheel.
yea. I think ima go with the act stage 1 and the 11.4 lbs fw. I dont wanna change the clutch out soon but hey I wanna run the **** outa the 5.0 that my buddies manager has so.... but my clutch should hold up just when its time to change it out i dont want any hesitation on what i need to get b/c its my DD so i gotta get the parts and change them out ASAP.
^word. same here.
i try to prepare for the inevitable.
i was contemplating on buying a clutch kit the other day from act, since they are 15 mins away from me, i was gonna run down and pick one up and just hold it till the day comes.
colbynorwood
Transmission & Drivetrain
Mar 16, 2011 06:42 PM
lkailburn
44
Sep 28, 2004 12:02 PM
beandip
Nov 23, 2003 11:31 AM
