Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rear sway bar question!
Old Jul 9, 2009 | 03:15 PM
EK99hatch's Avatar
Default Rear sway bar question!
I have a 96 cx hatch with koni yellows and ground control coilovers with the standard spring rates and 195/50/15 falken ziex ze912's. I have installed a 99-00 si 26mm front sway bar. Here is my question. I have the chance to buy a stock 99-00 si rear sway bar (13mm) for $50 or an m-factory (22 or 23mm) rear swaybar tiebar reinforcment setup for $150. Which would be the ideal one to get for everyday driving and maybe occasional track events?
Thanks
Scott
Old Jul 9, 2009 | 03:36 PM
cbstd's Avatar
Default Re: Rear sway bar question!
Hondas (and most street cars) come from the factory with lots of understeer built into the car's suspension. Adding the stiffest rear sway bar you can will kill most, if not all, of the car's understeer.
Old Jul 9, 2009 | 07:06 PM
Stinkycheezmonky's Avatar
Suspetise...
That is a terrible suggestion for a random inexperienced dude with a street car. You absolutely do NOT want that in that situation.
Scott, it sounds like you have no experience on track. Given that, I'd keep things cheap and simple and stick with the Si bar if you really want to get one. The better option is to forego that altogether and get out to a track event with that money instead. You just plain do not need any kind of swaybar-induced rotation on the street, ever.
For more information on all that, please use the search function (as this has been covered a gillion times here). Follow these instructions, using "Swaybar" or "Sway bar" as the search term: https://honda-tech.com/forums/showthread.php?t=2576327
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
EK99hatch
Suspension & Brakes
11
Jul 14, 2009 02:52 PM
EK99hatch
Jul 10, 2009 05:53 AM
Jamarquis
Suspension & Brakes
Oct 15, 2008 01:57 PM
VeilSide_Mas
Suspension & Brakes
Apr 24, 2007 12:13 PM
