Sway bar question!
I have a 96 cx hatch with koni yellows and ground control coilovers with the standard spring rates and 195/50/15 falken ziex ze912's. I have installed a 99-00 si 26mm front sway bar. Here is my question. I have the chance to buy a stock 99-00 si rear sway bar (13mm) for $50 or an m-factory (22 or 23mm) rear swaybar tiebar reinforcment setup for $150. Which would be the ideal one to get for everyday driving and maybe occasional track events?
Thanks
Scott
Thanks
Scott
Cool Cool Island Breezes. BOY-EE
Thanks
Scott
Thanks
Scott
I have a ITR 22MM bar that I found at a junkyard for $20 with brackets on my EM1 with ground controls and it handles great.
You definately have to get a subframe brace for anything that big to be safe...so that M factory deal sounds pretty decent.
You're going to need RLCAs that have a swaybar hole in them, though.
Do you have links to this M factory part?
...you also need D brackets, links, and a subframe brace to go along with it.
EK4civichatch
25
Sep 12, 2015 03:34 PM
Falloutkid90
14
Jul 21, 2015 05:31 PM
