perfect throttle body size?
Old Jul 9, 2009 | 01:57 PM
yoRt's Avatar
Default perfect throttle body size?
ok well im in the process of building a motor and am curious to know how would one estimate the "perfect" throttle body size for any motor.
specs
-b16a3 block
-b17a1 crank/rods
-.25 over p73 pistons
-blox intake mani thats been p&p'd
-62mm itr throttle right now
-rc 310's
-prolly mill/deck the block/head .020
the compression should be around a low-mid 11. i want a motor that works well together and my focus will be on the suspension.
Old Jul 9, 2009 | 01:58 PM
all-mtr-teg's Avatar
Default Re: perfect throttle body size?
What cams? If its gonna remain a mild NA build, keep the ITR TB
Old Jul 9, 2009 | 02:00 PM
yoRt's Avatar
yup itll be n/a. the head will be a 99 up itr head, stock valvetrain maybe p&p it a little more.
Old Jul 9, 2009 | 02:02 PM
What's on the menu for the exhaust system?
Old Jul 10, 2009 | 12:13 PM
yoRt's Avatar
some sort of custom 2.5 w/ mandrel bends, no cat.
Old Jul 10, 2009 | 01:08 PM
Sweet, how about header?
Old Jul 10, 2009 | 07:49 PM
RpWolfSH's Avatar
"perfect"? youll have to check on a dyno i guess.
From some 240 forum (use info at your own risk)
http://www.240sxforums.com/forums/ka...ade-guide.html
"Determining TB Size:
The best way to find out if your TB is too small for your IM plenum is to determine what the intake manifold absolute pressure (MAP) sensor is reading (in the plenum) when you are at full throttle ( or wide open throttle (WOT) ) while the car is accelerating using a datalogger. The MAP should be equal to, or close to, atmospheric pressure. If it isn't or there is a MAP drop at WOT, then your TB is still too small."
Old Jul 11, 2009 | 11:08 AM
yoRt's Avatar
makes sense.
408EJ1
19
Dec 17, 2012 06:48 PM
brand_NOOBian
Mar 31, 2007 04:43 PM
2k1_ITR_0736
Jan 25, 2004 05:06 AM
JDMvtecDRAGSTA
Nov 18, 2003 11:38 AM
JohnnysEG
May 19, 2003 08:57 PM
