iacv? b18 in ef
ive a a ls swapped ef, never had any problems with it til the other day. its started ideling in between 1200-1400
and the iacv are cleaned, i did a wire tuck so i got rid of some vacume lines, could someone tell me what vaccume lines are absolutely needed?
You need the vacuum line to the MAP if you're running a firewall MAP, and the vacuum line to the fuel pressure regulator. That's it.
Also consider replacing your PCV, if it's stuck open (and if you still have it). Try setting your throttle stop as well.
mybikeisblack, there should be a bleeder nipple at the top radiator hose. I've had mixed results using it, and as mentioned earlier I usually bleed via the rad cap instead. Depends on if your block or your rad cap is higher.
roll8221
Engine Management and Tuning
Apr 1, 2015 11:29 AM
89CivicHb1
Sep 13, 2008 02:44 PM
CorrodeONE
Jun 11, 2008 07:30 PM
