removing seats from 90 crx si
Old Aug 22, 2002 | 11:20 AM
rasta420's Avatar
Default removing seats from 90 crx si
what are the steps to removing the seats from my 90 crx si? how hard and how long would this take? is it hard to reach the bolts on the other inner seat rail?
any advice is appreciated...
thanks
Old Aug 22, 2002 | 11:58 AM
EL Vap133's Avatar
Default Re: removing seats from 90 crx si (rasta420)
4 bolts and it is very easy....
Old Aug 22, 2002 | 12:16 PM
whizdumb's Avatar
Default Re: removing seats from 90 crx si (Vap133)
yeah, removing the seats is one of the easiest things you can do... unless one of your bolts are seized and stripped like mine.
5 out of the 6 bolts were off in 5 min, the other one took 2 hours of trying at it. Finally had to grind it off.
But yeah just slide the seat all the way forward, get the back two (bolts are usually covered by plastic).. then slide it all the way back and get the fronts.
Old Aug 22, 2002 | 12:54 PM
pfcfutrell's Avatar
Default Re: removing seats from 90 crx si (shiznattik)
Hmmm... there's four bolts and one wiring harness for each seat.
1. Pop off all the plastic covers (one at each corner of seat).
2. Slide seat all the way forward
3. Remove rear bolts (10 or 12mm I think)
4. Slide seat all the way back
5. Remove front bolts (see #3)
6. Disconnect little wiring harness under seat
Installation is the opposite.
chunkybs
24
Apr 23, 2006 01:56 PM
SomeDude56
Nov 13, 2005 10:01 PM
Seedc2
Mar 9, 2003 05:20 PM
CivicBoi
Mar 5, 2003 04:40 PM
markpaco
Oct 12, 2002 04:16 PM
