Help!! Car wont start
Old Jul 9, 2009 | 05:34 AM
brandon43's Avatar
Default Help!! Car wont start
Ok, I have a 96 civic hx it had an automatic in it at one time but now is a stick(swapped out by previous owner). I had the car running yesterday, started up fine, but about an hour or so later I went to start it up and nothing no cranking no clicking nothing. I checked the starter and it fine, I replaced ignition switch still nothing, I check all fuses unless i am missing one and they are all fine(even replaced them to be sure). I still got nothing, the wires for the clutch pedal were never hooked up so thats not it either. Is there a relay i am missing or something else?
Old Jul 9, 2009 | 06:02 AM
wrenchez81's Avatar
Default Re: Help!! Car wont start
are the wires for the clutch interlock switch bridged?? if you just leave the connector off the switch will be permenetly open circuit and u won't get a start signal...
does the car have a security system?
Old Jul 9, 2009 | 07:00 AM
brandon43's Avatar
I figured it out..the old auto shifter was in drive...thanks!!
NoLimitCivic
May 9, 2012 12:09 PM
willskillz805
Jul 30, 2010 03:34 AM
daniel990836
May 28, 2009 09:57 PM
tampabitches
Aug 14, 2006 02:56 PM
wood
Aug 16, 2005 07:09 PM
