Need HELP! Coolant going str8 thru block!!
Old Jul 9, 2009 | 04:22 AM
jksmith's Avatar
Default Need HELP! Coolant going str8 thru block!!
I have a built NA LS/Vtec, b18b w/ b16 head.
I just changed my Headgasket and installed a breather setup, using a Freeze plug in the hole where would be on the PCV black box and, -10 port on the back of the block, and capped off the other line that went to the pcv box!
that is all i changed with the motor and had no problems before..
I used a OEM B16 headgasket !
problem is Coolant is draining and mixing with the oil as fast as i can poor it into the radiator? Its going str8 thru the block and into the oil pan!!
Anyone have any idea as to why?
Old Jul 9, 2009 | 09:03 AM
jksmith's Avatar
Default Re: Need HELP! Coolant going str8 thru block!!
37 views no opinions ???
Old Jul 9, 2009 | 09:14 AM
hondapowerb16a2's Avatar
do you have any pics of how you installed your breather lines?
Old Jul 9, 2009 | 10:07 AM
jksmith's Avatar
no i dont, im at work now will try to get some tonight, if possible.... i think: when i was putting everything back together there was a vacuum line that came off the TStat housing i hooked it back up there, i think i ran it to where the PCV connected to the block, going to verify that when i get off work tonight
would that cause this problem tho?
breather lines are set up
Can to VC and Port (one that uses a 14mm hex to get out) from back of block to Can
Old Jul 9, 2009 | 11:16 AM
88Hatchy's Avatar
So, you basically connected the cooling system to the intake?
Old Jul 9, 2009 | 02:33 PM
jksmith's Avatar
yep and that was the problem had coolant line ran to the pvc line, but i got it fixed and after several flushes with oil thru the motor everything looks good!
67mmlsv
Oct 22, 2012 12:23 PM
mtownsi
Apr 25, 2007 07:56 AM
RexB16
Apr 23, 2002 01:07 PM
