will a p06 ecu work on an ef thats duel point?
Old Jul 8, 2009 | 11:31 PM
xwhitchx's Avatar
Default will a p06 ecu work on an ef thats duel point?
will a p06 obd1 ecu work on an ef thats duel point obd0?
Old Jul 9, 2009 | 01:02 AM
4gen5thtime's Avatar
Default Re: will a p06 ecu work on an ef thats duel point?
No the plugs are different for one. You will also have to do a mpfi swap and swap it to obd-1 not hard to do. and it will make the car a hell of a lot better.
Old Jul 9, 2009 | 01:10 AM
BLOWNEF9's Avatar
And then run with the cel on because of the lack of vtec on your d15. Just get an ecu that was designed for your car. It will save you so many problems.
Old Jul 9, 2009 | 01:27 AM
Eighty-Nyne's Avatar
just buy a pm5...
they're like 10 dollars.
Old Jul 10, 2009 | 10:47 AM
xwhitchx's Avatar
p06 in a non-vtec ecu, i dont think im going to get a code.
Old Jul 10, 2009 | 11:33 AM
NO IT WILL NOT WORK!!! Ok I thought I said it clearly enough. But no It will not work. The end.
Here is why it will not work
Your car is obd-0 the p06 ecu is obd-1. Also your car is dpfi and that ecu is ment to run mpfi. You will need to do a mpfi swap. Then you will need to do a obd-1 conversion.
vw40life
Apr 20, 2012 05:09 PM
B18dego
Engine Management and Tuning
Apr 7, 2012 06:28 PM
Choy
Feb 2, 2010 07:21 PM
FOMULA91
Jul 18, 2005 01:31 AM
