Does your 02 sensor effect your gas mileage?
My question is:
Does your 02 sensor effect gas mileage?
I have a 97 del sol. Installed ebay headers [only had one bung hole for one 02]
My car has 2 02 sensors. I took off the 02 sensor that was after the CAT.
Is this bad? i really don't mind the CEL but i'm wondering if this is effecting gas mileage.
First thing... Please read the Forum Rules sticky. Create threads with proper subject matter, not just "help" or "one question"...
On to your issue. The second O2 is strictly for emissions purposes, it will not effect gas mileage.
I would suggest fixing the CEL. You could have other problems down the road and wouldn't know because your CEL would already be on, and it just looks goofy. To fix it you have a few options....
1. Search for an O2 simulator that plugs in where the 02 used to.
2. Weld in a bung
GL OP
2. Weld in a bung
GL OP
okay, thanks. Btw, before i the header, i didn't have any issues with the car, no cel, the car ran perfect. The cel right now is because of 1:Header flow for the 1st 02 and 2:i don't have the 2nd 02 plugged in
Flow will not throw a CEL.....
The second 02 is strictly designed to measure hydrocarbons for emissions purposes. This in turn shows if your catalytic converter and other emissions equipment is functioning properly.
I assure you that if you scan your car it will be throwing a single code caused by the 2nd 02.
Did you eliminate the cat when installing the header? Test pipe?
just plug the secondary o2 back into the harness and ziptie it up to a)something on firewall b) something on the engine like intake mani c) anywhere it will reach
no need to weld a bung in or anything, secondary o2 is meant to be after cat where the air should be somewhat clean so dangling in the open will trick it to think its reading clean exhaust and Bam
NO CODES
NO CODES
NO CODES
NO CODES
NO CODES
NO CODES
The first 02 sensor is the only one that really has any bearing on your gas mileage. It sees your AFRs in the exhaust pre-catalytic converter and adjusts fuel based on that. The second O2 merely keeps an eye on the catalytic converter. As long as it sees clean air and a certain amount of heat, it won't throw a CEL. Most people zip-tie this 02 sensor near the exhaust but let it dangle in free air. There are also 02 delete kits available online for very little $$ if you want to go that route.
yes, youre o2 sensor effects your gas milage. I drive a 01 Acura Integra GSR and before i installed my new o2, i was getting about 170 miles to the tank. thats fu*king HORRIBLE! after i installed my new o2, im getting around 250-275 miles to the tank. it has improved 100 miles to the tank.
WangChung
Oct 21, 2003 02:47 PM
