Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Hello, new here and am considering a 2006
Old Jul 8, 2009 | 07:59 PM
beedees's Avatar
New User
Default Hello, new here and am considering a 2006
Acura TL and would like to know if there are any issues re. engine, trans. etc. I would like to know especially if the V6 is an interfence motor and does it use a timing chain or belt? Thanks
Old Jul 13, 2009 | 09:21 AM
mugen88crx's Avatar
Default Re: Hello, new here and am considering a 2006
It's a timing belt setup unlike the K series motor (TSX & RSX). Rarely are there transmission problems with this generation TL. Sometimes in the 6-spd it has a tendancy to pop out of third gear. Check to see if this service bulletin has been done (if it's manual trans). If its an automatic, we have had a select few come in with bad trans, but nothing like the older model TL.
Other than that there are only three major bulletins...
*Front Windows Stick or Dont Go Down/Up.
- Replace the regulator, run channel molding and wipe molding.
*High Pressure Power Steering Line
- Replace (Covered under a safety recall so it has to be done warranty)
*Wiper Motor Does Not Work or Sticks
- Replace Wiper Motor & Trans Assembly (also safety recall)
Thats really about it...
Oh forgot one... Fuel Pump Relay (car starts rough or not at all)
Old Jul 13, 2009 | 09:26 PM
Danronian's Avatar
Just bought an 04 TL myself with 69k miles on it. When should I address the timing belt?
Thanks!
Old Jul 15, 2009 | 07:37 AM
mugen88crx's Avatar
Generally your 105k service but some dealers may try to sell it to you at 90k.
Old Jul 18, 2009 | 05:13 PM
94eg!'s Avatar
#1 Super Guy
Loved
FYI: All Honda's are interference engines. In fact, I think all modern motors are interference engines from all brands. Compression is important to performance, and relatively flat pistons are important to thermal effeciency...
pcollino
Acura TL, RL & ZDX
Sep 2, 2009 02:10 AM
93baggedcivic
Jun 10, 2007 09:06 AM
Mr.Luder
Mar 15, 2007 03:38 AM
Beau Gotti
Jul 1, 2006 08:03 AM
coot_er
Sep 15, 2005 09:20 AM
