brake lights will not turn off
Brake lights will not turn off even when the car is off and the key is out. Is this the brake light switch doing this? I had installed a new one a while back but my roomates just notified me they were on. Could it be anything else? All the turn signals and hazards work fine, and it was a Major pain in the *** to put the petal switch in the first time. Please tell me it is something else.
Any help would be super.
Gah. I looked under there and the little rubber arrow it rests on is cracked and a piece fell off when i touched it.
But it still makes the switch go in. Hmmm. I hope this is the problem. I do NOT want to have to mess with that switch again. It was deathly hard to get the plug in the back of it.
The rubber/plastic pad it rests on is accessible. Hopefully it is the culprit. I have been looking for an hour now to find the part number or name of part but cant locate it. might have to ride my bicycle all the way to the auto parts store.
if the rubber stop on the brake pedal rotted off or cracked off then that is you problem. The same thing happened to me in my DA, I just got a small bolt/washer and nut combo and bolted it in it's place and haven't had a problem since.
super! i got a bolt and nut/washer on there now. Works perfect! Thanks you guys. Just in time too. I got a 2 hour drive to Hempstead planned later tonight.
crxtreme27
Apr 20, 2003 01:37 PM
