Those who know
Old Jul 8, 2009 | 03:08 PM
madgeo's Avatar
Default Those who know
I 'm doin a B18B swap into a 90 crx hf. My speed sensor for the swap will be electric and my gauges for my old engine is a cable driven. How would i convert over to make everything work the way it should? Any help so i can finish this swap up???
Old Jul 8, 2009 | 03:24 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Those who know
just unbolt the electric from trans and use your d-series one. they are both the same. or you can order or find a DA teg one that will be the exact right part.
Old Jul 8, 2009 | 03:45 PM
black0hatch's Avatar
the d series one is a little shorter or a little longer i dont remember but it will work. or you could get a cable driven one off a da integra. either one will work.
Old Jul 8, 2009 | 04:32 PM
ek-g6's Avatar
x2 it will be cheaper, and also, you dont have to rewire and get a new gauge cluster just to make it work.
Old Jul 9, 2009 | 03:21 PM
madgeo's Avatar
Does any one know how to remove the old one off the old trany?
I used PB Blast,tried cleaning around it to see if it move and nothing.
Old Jul 9, 2009 | 03:54 PM
BLOWNEF9's Avatar
Did you take out the bolt? I think it's a 10 mil bolt right next to the vss.
Old Jul 9, 2009 | 04:02 PM
madgeo's Avatar
took that out, just tryin to find out how to take it out w/o messing it up
Old Jul 9, 2009 | 04:05 PM
BLOWNEF9's Avatar
Should just pull straight out then man. I'm sure it is just gummed up a bit from being on there for 20 years. Can you get it to spin at all or does it seem to be frozen in place?
Old Jul 9, 2009 | 04:06 PM
madgeo's Avatar
i can get it to spin but thats all its doin
Old Jul 9, 2009 | 04:09 PM
BLOWNEF9's Avatar
Hmm...should come out. I don't know what to tell you. Try to pry it out?
Old Jul 9, 2009 | 07:59 PM
sanimalp's Avatar
$cat /dev/urandom
have someone rotate the front wheels of the car or the input shaft of the tranny back and forth a little while you try to shimmy the vss out. it should come right out easily.
RACEPAK
Nov 9, 2023 07:24 AM
Nutnwrench
11
Dec 11, 2007 11:35 AM
pouponu
Oct 14, 2007 01:06 PM
silverspins
Jun 17, 2004 10:02 AM
xci_ed6
Aug 9, 2003 09:03 PM
