can i pass smog with b16a2 with ctr piston and itr cams???
Old Jul 8, 2009 | 09:25 AM
mynameizstitch's Avatar
Default can i pass smog with b16a2 with ctr piston and itr cams???
ok i live in california where smog sucks. will i pass smog if i was to have ctr pistons and itr cams? everything else will be stock and i will be running the stock ecu when smoging the car with a new cat welded on. my only concern is that the ctr pistons will raise the compression up so i may fail. there is no way they will know i have ctr pistons and itr cams though. anyone done this in california yet??? let me know thanks.
Old Jul 8, 2009 | 10:36 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: can i pass smog with b16a2 with ctr piston and itr cams???
can you leave it stock and go test, pass, then put the pistons and cams in?
Old Jul 8, 2009 | 10:53 AM
fungus mungus's Avatar
That buys the OP 2 years...but I think he'd like to know if it will pass so he knows whether to use the ITR cams and CTR pistons.
Pulling the motor apart in 2 years because it fails smog will be a major PITA.
fm
Old Jul 8, 2009 | 11:06 AM
will im building a motor that will last more then 2 years so i dont want to have to take the motor off just to smog and put back in thats why
Old Jul 8, 2009 | 11:07 AM
I'm not Rick!
unless you put a dif engine in. every time you go test put in a stock d15 or something. can people do that in cali?
Old Jul 8, 2009 | 11:24 AM
B16AGUY's Avatar
lol I doubt anyone would like to swap out their engine every two years just to go pass smog.
With stock ECU it may pass still...
What abou tthe I/H/E?? will they all be stock or aftermarket?
Old Jul 8, 2009 | 11:43 AM
right now i have aftermarket intake header and exhaust but they are all carb legal. aem intake and dc header. i still have my stock parts that i can put in just in case.
mynameizstitch
Northern California
Jul 22, 2009 09:46 AM
DC4R27
20
Jan 26, 2007 06:01 AM
bucdenny
Feb 17, 2006 05:32 PM
Rincon
16
Nov 1, 2004 07:18 PM
toohott4handlin
43
Apr 28, 2004 01:27 AM
