S2k Cluster FS (any offer will be accepted!)
Old Jul 8, 2009 | 09:23 AM
cvcrcr99's Avatar
Default S2k Cluster FS (any offer will be accepted!)
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
Hey H-T. I got this s2k cluster off a friend of mine. He had it in his 06 RSX type S. It originally came from an 01 (ap1) S2000. I had plans of putting this into my Civic, but ended up choosing a SI cluster instead for money reasons. There is a problem though, right above the "SEL", there is a minor crack in the LCD screen. It doesn't affect the performance, but dI got this s2k cluster off a friend of mine. He had it in his 06 RSX type S. It originally came from an 01 (ap1) S2000. I had plans of putting this into my Civic, but ended up choosing a SI cluster instead for money reasons. There is a problem though, right above the "SEL", there is a minor crack in the LCD screen. It doesn't affect the performance, but doesn't look too pretty. Check the pics. Make an offer. I am not trying to make money off of this, just trying to get rid of it.
Here's a pic of the damage:
(don't mind the dust, just needs to be wiped off)
As I stated above, everything should work just fine, just the part of the RPM band that is affected may be blurred when/if you rev up that high. I do not have the plugs for the cluster, but has wiring coming out the back from when it was used on the RSX type S.
In order for this to work in your car, you will need:
- Your car's cluster wiring pinout, s2k cluster pinout (I can provide that if need be)
- Speedo-healer (unless being installed in a 05-06 RSX type S)
- EGT module from modifry.com (unless you don't care if the engine temp thingy doesn't work)
MAKE AN OFFER. Trades for parts for a 99 Civic welcomed! Nothing within reason will be denied! I just want this out of my dining room.oesn't look too pretty. Check the pics. Make an offer. I am not trying to make money off of this, just trying to get rid of it.
MAKE AN OFFER. Trades for parts for a 99 (6th Gen) Civic welcomed! Nothing within reason will be denied! I just want this out of my dining room.
Old Jul 9, 2009 | 11:30 AM
cvcrcr99's Avatar
Default Re: S2k Cluster FS (any offer will be accepted!)
Bump for pending sale!
Old Jul 12, 2009 | 07:38 AM
cvcrcr99's Avatar
Bump for still being available!
Old Jul 13, 2009 | 08:38 PM
cvcrcr99's Avatar
ttt
Old Jul 14, 2009 | 08:31 AM
cvcrcr99's Avatar
Bump for a crack in my windshield that needs to be replaced!
SOKDO
Jan 30, 2015 06:49 PM
ReDrAnGeR
Oct 8, 2010 08:57 AM
cvcrcr99
Northeast (Sales)
Jul 14, 2009 08:31 AM
S2k Hybrid
Aug 9, 2006 08:15 AM
