tach and distributor problem
I recently changed my cap.and since I've changed it my tach doesn't want to work. My engine is dpfi and the cap was from a mpfi. Does it matter? The look similar. But the outside has differences? Anybody know? Thanx
yea i runs good except i get a code 20 after driving for a few mins and when i start it, it misfires a lil bit until its warm but maybe the code 20(i think its a eletrical load detector?) could be effecting it?
It might effect it. Check the Fuse under the hood make sure it wasnt blown, then if all else fails iv seen that replacing the whole underhood fusebox gets rid of the ELD code.
20 a code 16 and a code 1 I tried to erase those codes and as soon as I do the code 20 comes up then both the 16 and the 1. Comes up . Ma head is just hurting over this lol ill replace the under hood. Box and see what happens
The cap was bad and I had a d16a1 dizzy cap layin around didn't think anything of it so I used it
Ill get another cap and see what's up
kamakaze1
Jul 28, 2006 11:06 AM
