94 Integra GSR Motor For Sale
Ok heres the scoop. This is still in my car so you will be able to hear it run before buying. I will require a non refundable deposit before pulling should you decide to buy it. That way I don't pull it and you change your mind on me. Motor has 191,xxx miles on it. Rarely ever see's vtec. I have had motor for 12k miles and 10k of those are highway miles.
I did snap a timing belt about 2 months ago in it and clipped #1 exhaust valves. I was going less then 20mph when it happened. It does chatter and have a little miss to it. It uses about a quart of oil every 2 weeks or so. I put a new timing belt on it and have driven it since then. It still runs very strong and gets about the same gas mileage as before the T-belt snapped.
I just got my beater fixed and am getting ready to put new motor in teg.
Heres what you get with motor:
Complete head minus Vtec Selinoid (I can give you a broken one that you might be able to JB Weld
Complete Block
No Starter/Alt/Intermediate Shaft/Dizzy
$900 obo picked up. If you want it shipped its going to be atleast an extra 200 dollars
Heads are going for 450 alone on ebay.
Complete Block
