ls swap Qs
Old Jul 7, 2009 | 11:53 PM
brownsEF's Avatar
Default ls swap Qs
i was running a dohc zc with a pr4 do i have to change anything else from the harness?
Old Jul 8, 2009 | 01:01 AM
tek44's Avatar
Default Re: ls swap Qs
? give some more detail it would help
Old Jul 8, 2009 | 09:03 AM
dephtone's Avatar
Everything will plug in on the harness. You will not have to change anything wires wise.
Old Jul 8, 2009 | 09:37 AM
PiKapp504's Avatar
Unless you changed your dizzy plug from 7 wire to 5 wire and used the ZC's CPS that's located on the exhaust cam. My buddy did that and now has to convert BACK to the original 7-wire dizzy plug...just a little FYI in case you run into that issue. If you used a stock Si/HF to ZC adapter, then you should be good to go.
Old Jul 11, 2009 | 12:50 PM
brownsEF's Avatar
yeah im a have to convert back to the 7 wire dizzy plug
Old Jul 14, 2009 | 08:46 AM
brownsEF's Avatar
what about the map sensor?
use the same 1?
stickman78114
Feb 21, 2010 09:37 AM
brownsEF
Jul 21, 2009 06:42 AM
C_R_X_V_T_E_C
12
Mar 20, 2007 01:06 PM
99sonicbluegsr
Sep 16, 2004 07:43 AM
