EG with b18 ls vtec
Old Jul 7, 2009 | 10:12 PM
S_K_C's Avatar
Default EG with b18 ls vtec
I everyone im a noob but im tyring to learn fast....im looking to buy an 1992 si eg with a B18 Ls motor/transmission. the swap was from a 96 integra. i just want to know everyone opions on it good and bad
o yea and what does everyone think of the eg halo lights....
Old Jul 7, 2009 | 10:24 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: EG with b18 ls vtec
Well you should do a compression test/leakdown test to see if the motor is good.
EG halo lights = ricer.
Old Jul 7, 2009 | 10:27 PM
S_K_C's Avatar
ok thank and lets say i go check the car out and everything is fine what kind of hp would i be pushing to the wheels.
haha true but they look cool
Old Jul 7, 2009 | 10:48 PM
forcefedferio's Avatar
<100whp/>120whp i'd say, you're going to get different results from dyno to dyno and depending on altitude and temperature, things of that nature. so assuming it would be a strong motor accounting for a 15% drivetrain loss you would be floating somewhere between 100-120whp. Just remember with hondas it isn't about how much power in numbers.
Old Jul 7, 2009 | 10:56 PM
S_K_C's Avatar
o ic so is it worth it? and can a compression test and leak down test be performed at any auto shop like a pep boy or what ever? and if it isnt good can it be fixed easliy?
Old Jul 7, 2009 | 11:07 PM
maxwellmercer's Avatar
leakdown tests are pretty easy but, dont buy it if the numbers are low.
Old Jul 8, 2009 | 02:14 AM
MHDesigns's Avatar
What most people who don't run these motors think(or dont know honda motors in general...) is that they are all the same...HAH!!
I'm putting down 192whp on my Ls/vtec. I'm also running ITR pistons bigger injectors,TB,Cams,Intake,etc,etc,etc.... It all depends on what your running inside the motor. LS/vtec just means b18A or b18b with a vtec head. what head is it? What pistons/rods/cams/etc. Better question is what is the Compression ratio?
Its not like a GSR or std B16 swap... nobody can ever tell you how much power a "stock" ls/vtec is making without knowing exactly what its made of....
Personally though... I would never buy a used ls/vtec.
Old Jul 9, 2009 | 01:24 AM
wickedvybzcivic's Avatar
true and true
s2k_al
Mar 18, 2006 02:25 PM
DualCamEK
Feb 22, 2006 10:52 AM
pep
Sep 11, 2003 08:02 PM
synergy004
Aug 23, 2001 11:00 AM
