Core support welding question! PLEASE LOOK
Old Jul 7, 2009 | 08:02 PM
roller3804's Avatar
Default Core support welding question! PLEASE LOOK
I have taken my front radiator support off on my 94 lude. I drilled all the spot welds out and have gotten an OEM replacement.
What is the best way to weld the old one back on? Should I use a small mig and weld from the back? Or get a spot welder and just tack it wherever there is metal to metal areas with no holes drilled?
Any advice is appreciated!!
Old Jul 7, 2009 | 11:13 PM
duffman1278's Avatar
Default Re: Core support welding question! PLEASE LOOK
You should be able to fill in the holes with a MIG but at the same time weld the two metals together. If you're penetrating them then it should be set.
Old Jul 8, 2009 | 03:08 AM
m R g S r's Avatar
clamp it first and make sure all the body panels/headlights line up first. don't weld it then find out it's too late and it's off!
wdissident
Feb 18, 2009 05:00 PM
SIRIUS VTEC
Jun 8, 2008 12:14 PM
Double Agent
Apr 11, 2006 09:50 AM
De_tour
Nov 3, 2005 05:59 PM
1fastVX
Welding / Fabrication
19
Jun 28, 2005 02:55 PM
