Part out. Full-race, Garrett, precision, Tilton, lenso, aermotive + more
Here is my list of parts that I have from my part out. Most parts are basically new. 2 passes were put on these before I realized it was time to move on. Great deals and I will ship asap!
Precision 1600cc injectors. SOLD
Blox 76mm polished throttle body with tps sensor.
MSD digital 6, MSD hvc II coil, MSD billet distributor, plug wires, techedge wideband. COIL SOLD
Full-Race traction bars.
Golden Eagle scatter shield
Full-race t4, divided manifold. PERFECT!
Titlton twin disk, less then 50 miles. Has 2 master cylinders, hydrolic release bearing, stainless line, and fluid control valve.
Precision 825 (big one) intercooler
4" downpipe, made to fit full-race top mount, with gt42r/s372
Sleeved LS block, line bored and gsr gurtel installed. Carrillo rods with CARR bolt, CP pistons, Micropolished crand, AEBS crank cap studs, RS machine sleeves, o-ringed, all new gaskets. Runs great has 2 passes on it. BRAND NEW basically. 84.5mm SOLD SOLD SOLD
Aeromotive eliminator fuel pump with aeromotive fittings. Fuel lines -8 feed and full-race sumped gast tank for sale as well. -8 FEED line SOLD. PUMP still available
MOMO steering wheel, brand new, has quick release and hub. SOLD
DEFI gauges with control unit. EGT, Boost, EGT. SOLD
Stroud window net. SOLD
Lenso VDP rims with MT 24.5" slicks SOLD
Eddlebrock victor x manifold set up for 8 injectors SOLD
Stroud harness
4" aluminum exhaust, wtih burns muffler. Back section needs to be finished so it should fit just about all popular models.
GSR head with Ferrea dual valve springs and ti retainers. Ferrea 1mm oversized intake and exhaust valves, fulley port and polished, all new seals and valve guides. Comes with all cam caps and LMA's. SOLD SOLD
GT42R with polished compressor, and HPC coated exhaust housing. Will come with a brand new center section from garrett and fittings.
I also have misc oil and fuel lines and fittings, let me know what you need and I'll check for you.
Thanks Jesten
801-916-4130
utahbmx@yahoo.com
Stroud harness
Thanks Jesten
801-916-4130
utahbmx@yahoo.com
utahbmx
Jul 21, 2009 06:22 AM
Cwest EK
Aug 30, 2007 09:14 AM
