Apexi N1 B pipe will stock axelback bolt up? NEED HELP ASAP!
Old Jul 7, 2009 | 02:49 PM
SpadedEK's Avatar
Default Apexi N1 B pipe will stock axelback bolt up? NEED HELP ASAP!
i have a full exhaust system, dc headers, omni power test pipe and an apexi n1 catback. i am sick of dealing with load exhaust tickets, half the reason i get them is because of the huge chrome can chilling under the back bumper. so the question comes up, if i purchase a stock axelback direct fit (oem quality replacement) will it bolt up to the apexi n1 properly. this would be the best way to keep the po-tron off, im sure its very quiet at cruising speeds and would only get really load if i hammer it and also it is stock so the looks dont attract attention.
Old Jul 8, 2009 | 04:50 AM
SpadedEK's Avatar
Default Re: Apexi N1 B pipe will stock axelback bolt up? NEED HELP ASAP!
bump
Old Jul 8, 2009 | 04:59 AM
MHDesigns's Avatar
Just do the whole cat-back. you can run huge piping wherever you want but it will get restricted anyway in the end if you use stock. I do NOT mean restricted in a bad way though. Hondas exhausts flow pretty good stock(Generally the header is all thats really needed+oem catback). Not only that but you could probably get a nice chunk of cash from your old N1.
Your only gonna be losing like 3hp so just pull the whole thing.
Nsane
Aug 5, 2005 03:12 PM
_gurusan_
Feb 10, 2005 05:42 PM
Vtec integra
Apr 10, 2002 01:04 PM
