"diesel" sounding noise since water pump was changed
My water pump failed on christmas day, 2008. luckily, there was a lot of traffic so i was only going about 20mph and my pistons were not damaged. after my water pump was replaced, i noticed a "diesel" sounding noise when i accelerated when i arrived home. my water pump was installed at 7000 ft in elevation, and i live down the mountain. i can only hear the sound where i live, and when i drive up the mountain, the noise disappears. this is what made me believe it had something to do with air intake. it makes this noise very loudly when i accelerate onto freeways and up hills, and it seems more sluggish than it did before. it's even worse when my a/c is on. in fact, i was in a drive thru earlier today and noticed that when it was idling with the a/c on, i could hear the noise. when i shut the a/c off, the noise when away when i was idling. when i'm accelerating however, it's always there. my dad (who's also my mechanic) thinks that it doesn't affect anything. i've never overheated and my fluids are fine. i maintain my vehicle every 3000 miles, and this is the only thing that is really wrong with it. i can't put my finger on it. i also don't want it to get worse because i didn't take care of it. i cant figure out what i need to take care of! can anyone help?
I'm willing to bet you're hearing spark knock/detonation due to the timing belt being off a tooth (or more) and thus your valves are not opening/shutting when they're supposed to.
Who replaced the water pump?
Are you familiar with how to check your timing? Not just ignition timing with a timing light, but physically checking to see if your timing belt is installed in time?
BTW:
If my theory is correct it explains the noise, the loss of power, and why it's worse when the a/c is on as well.
It can absolutely destroy the engine if the detonation is strong enough - it can actually put little craters in the piston tops and even crack a piston ring landing. the noise you're hearing is little explosions due to the mistimed valve opening/closings.
If you lived in a really hot climate you'd be hearing it much worse too. I'm not sure how elevation affects it, but that can't be good either.
with it being timed incorrectly, that explains the sluggishness, the crappy gas mileage, the overheating, the noise and hiccups from a dead stop. THANKS GUYS!!!!!
Sorry to reply so late, and i have a feeling the OP might not be back to read this any time soon, but I thought it important to say this:
I'm not seeing a correlation between timing being off a tooth and overheating. In theory the poor timing could have been causing enough spark knocking, lean burning, and detonation to possibly cause overhating, but it's just not very likely IMO.
My hunch about timing was correct in that it took care of the diesel noise, but I would not have suggested timing being off as a cause for overheating...that's just odd.
I'd suspect something more along the lines of a thermostat sticking shut at random, vausing overheating.
pityocamptes
Dec 16, 2013 07:39 AM
djpuffball
Nov 16, 2001 02:09 PM
