Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need help: phantom grip differential upgrade or obx lsd
Old Jul 7, 2009 | 11:27 AM
Pleiadi79's Avatar
Icon6 Need help: phantom grip differential upgrade or obx lsd
What u think guys?
Is better upgrading stock differential, on b16a2 hydro clutch, with phantom grip lsd kit or using obx new lsd?
Yes i know quaife is better but for low budget?
Need suggestions...
Thanks
Old Jul 7, 2009 | 11:39 AM
Honda Bull's Avatar
Default Re: Need help: phantom grip differential upgrade or obx lsd
Neither. The Phantom Grip doesn't work so don't bother, and you're hit or miss on if you even receive a decent OBX unit. If you are on a 'low' budget, get an MFactory LSD and call it a day.
Old Jul 7, 2009 | 11:46 AM
Mista Bone's Avatar
D Tranny Guru
Mfactory or Quaife.....
Old Jul 7, 2009 | 11:47 AM
Pleiadi79's Avatar
Thanks , only i hadn't understand why obx does not works. Will it broke easily than stock?
Old Jul 7, 2009 | 12:04 PM
Aquafina's Avatar
OBX does not know how to machine. i.e. It will most likely be out of round. I don't install them anymore for this reason. 2nd to last one they sent me had .023" runout. The replacement for it was handpicked by them and had .005" runout, and 3 of the ring gear bolts made enough contact with the housing that they could not be tightened. I got a refund for the customer for it being defective, but they still charged their 30% restocking fee.
Old Jul 7, 2009 | 12:05 PM
K20egcw's Avatar
OBX diffs work good!! I have a friend runnin one in his 10 second car with NO problems, been runnin on it for a couple years now too
Old Jul 8, 2009 | 11:04 AM
Pleiadi79's Avatar
thanks to all i'm more confused than before!
i really don't know what to do...
Old Jul 8, 2009 | 01:04 PM
Mista Bone's Avatar
D Tranny Guru
Listen to Aquafina and me, there is a reason we stopped installing OBX's.
Old Jul 8, 2009 | 02:01 PM
Pleiadi79's Avatar
Thanks, i'll follow ur suggestions!
However how much hp can support stock trans without problems?
thx
Old Jul 8, 2009 | 05:58 PM
Honda Bull's Avatar
Depends on power / driving style / condition of parts.
From personal experience, my friends and I are making up to 480 whp without any issues with the STOCK B-series trans. But we only get to put on like 20-50 dragstrip passes a year on slicks, but drove them everyday almost.
K20egcw, you probably didn't install the diff to take a look at the quality and measure anything. You guys probably received by chance a decent one. One that I received didn't even have the ring gear bolts tapped, two washers were cracked, diff housing bolts not torqued evenly, and the washer shims weren't in any rhyme or reason. Sorry OBX, but no thank you. Not worth the hassle when I can drop a bit more on an MFactory.
Old Jul 9, 2009 | 03:02 PM
Pleiadi79's Avatar
I will use the car only on strip but i'm at the beginning and i'll use a stock block not already sleeved. So i'll not have a big power at wheel so i think stock trans will work fine for this year.
I also thinking to use the ph grip transmission cradle.Do someone already used? What u think? thx
Old Jul 10, 2009 | 09:12 AM
Aquafina's Avatar
Have a backup trans or two ready, you're going to blow the diff apart. Cradle won't do anything to keep stock gears from breaking once you have a lot of power.
Old Jul 14, 2009 | 12:36 AM
Pleiadi79's Avatar
thx i have 3 complete gearboxes ready....
I would like to use this setup for this year test..For the nxt i would like to installa a gearbox and lsd diff...
thanks.
Civic HX 121
Jul 2, 2012 09:06 AM
DJ Humpy
May 11, 2007 09:45 AM
discman
Jul 8, 2006 03:10 PM
Ruben19
Jan 17, 2006 04:50 AM
Sleeper32
Oct 21, 2003 10:53 AM
